Macintosh 128k~Plus Analog Board, Safety Capacitors C33, C37, C38
JDW
68020
I tend to swap out the electrolytics in a recap and leave the film or metalized paper caps alone if they are good.  Some among us have experienced blown filter caps near the power input on the original Macintosh analog boards, specifically these Rifa caps:
C33: 4700pf 250VAC Minibox (sometimes found to be 2200pf?)
C37: 4700pf 250VAC Minibox (sometimes found to be 2200pf?)
C38: 0.1uF 250V Minibox
The stock Rifa caps all appear to be metalized paper capacitors. A directed replacement for C33 and C37 would be the KEMET PME271YA4470MR30, also metalized paper.  But would a Polypropylene version safety capacitor like the WIMA MKY22W14703F00KSSD be a better choice?  There is also the KEMET F462AG472J1L2A polypropylene cap, but it is not classified as safety and therefore I do not know if it's failure mode would be open circuit when it blows.  Similar thinking should apply to replacements for C38
Please let me know your thoughts.
Thank you.
75 views of my opening post, but the only reply is mine. :-(
Since everyone appears afraid to reply, let it be known I am open to "speculation" too.
@Bolle?
@Bolle?
No idea. If I was to replace them I would go for what was in there originally.
I yet have filter caps to get blown on any of my machines. I'd probably try and see what happens when I just leave them out.
I have had a lot of RIFA caps failures, most of them in the Apple II series PSUs, but also in the Macintosh 128/52 and Plus units.
When they failed, it's a real mess, so i replaced all of them as a matter of fact.
Indeed, i have replaced more RIFA filters than electrolytics in the Macintosh Analog Boards.
Thanks for this!
Too bad they don't sell a ready-made set for analogue board/ps repair in an SE/30 too.
Probably because they haven't looked at one and made a list yet.  If you take your phone and take really close up photos of every capacitor with its board assignment number  such as C1, C2 etc and then one photo of the top and bottom of the entire board and send it to them, they will make a kit.  That is how I got them to make one for the plus, 128 and 512.
I have had a lot of RIFA caps failures, most of them in the Apple II series PSUs, but also in the Macintosh 128/512 and Plus units.
I had a RIFA cap explode in the PS in my Profile HD.
Also had one go in a 512K also.
Yep, replace them while you're in there.
Sorry to resurrect an old post, but I have had a couple of analogue boards with the 2200pF Rifas at C33 and C37. Are we in collective agreement then that the 4700pF replacements are preferred? It's what Larry Pina lists in his component list for those locations, but he makes no mention of the 2200pF components. I sort of understand that there is some wiggle room with those particular caps since they're safety caps, but I'm not an engineer, so the specifics of why particular capacitance values are selected is beyond me, and 2200 vs. 4700 seems a world apart to me.
The 4700pF I use are for the international 220V version. Don't know if there is a difference for the 110V version.
C38 is always .1µF (100nF) I believe, but C33 and C37 are 2200pF on mine (US). I do see in DogCow's post that their C33 and C37 are indeed 4700pF...
The C33 and C36 on the Plus analog board for international are 4700pF 250V caps.
The C37 is larger but also 4700pF 250V I believe
Wanted to answer these in case others land on this thread in future Google searches. The short answer:
Replace the safety capacitors with parts of the same capacitance and safety class as originally installed.
Or, longer: the safety capacitors, along with a choke, form the EMI filter at the AC input of the power supply. The exact values of the Y-capacitors are chosen in a compromise between the performance of that filter, and their leakage current to ground (remember, the Y's are connected between each of the line/neutral, and ground). The magnitude of the impedance of a capacitor, in ohms, is inversely proportional to its capacitance and the frequency of the signal passing through it. In other words, increasing the capacitance of the Y-capacitors will decrease their impedance at line frequency (50/60Hz depending on where you live) and increase the leakage current as a result.
This leakage current is tightly regulated by safety standards. According to IEC 60950, it must never exceed 3.5mA in this type of equipment. This is required in the event that the ground at the AC inlet isn't connected (e.g. due to faulty wiring). In that case your body could establish the ground connection, and an otherwise dangerous current would flow through you. Either 2200pF or 4700pF Y-capacitors should result in sufficiently low leakage currents even in worst case scenarios (there is some additional leakage past the Y-caps due to parasitic elements).
All that's to say: while moving up from 2200 to 4700pF is safe, your best bet is to stick with whatever was in there originally (thinking especially of other models of computer that may use wildly different values for the Y-caps than the early Compact Macs). These are absolutely not parts you want to experiment with, as you may put yourself or future owners of your computer in serious danger.
