Non bootable bin files (apple mac os 6.0.2-7.5.2 Greek Lang)
Good evening I discovered the problem because the file does not boot. The reason is that these files are in bin format so the program cannot recognize them as a floppy disk. How can i convert them to img and bootble ?
end in .bin
The program (Mini vMac) cannot recognize them and read them as an img boot disk.
The archives I downloaded and say are here for you to look for:
Look like binary files: use Stuffit Expander to extract the actual disk images.
Give me some info on what you say to the blind? Am I ancient by these I hardly ever have much if you could help with a little more with no guides or guides?
how do i do that?
Download a version of Stuffit Expander for Windows (use Google). Then use that to open and extract the files.
You can try that, but to be honest I’m not sure what those are. Send me a PM, and I’ll give you my email address. If you can send me some of the .bin files, I’ll open them on my old Macs and see what I can make of it.
Any newer friend of mine? check those I sent you with a personal message (I also sent you my email). what they say ; there is a way to pass them on vmac mini or to SheepShaver ;
