@techknight had posted this earlier in the thread, gotta find his GS Card development thread for more info.
The SE/30 is hampered by that darned video hardware, as its clocked off the main system bus and it doesn't use its own clock.
Once you get it off the dependence of that on-board video, than anythings possible. The Simasimac we are all known and accustomed to is generated from the video RAM at its initial power-up state, before the VRAM is ever initialized by the mac itself.
I did notice the simasimac is different between the 2 different RAMs used.
This tidbit appears to affect two concurrent projects, this one for my proposed testing methodology. Looks like I need to risk killing one of my IIsi boards in my first shot at a recap. :mellow: Again, when the IIsi boots without detecting sense line encoding, buffering of the first Megabyte of system memory as blood sucked VRAM does not take place. I imagine the IIsi might be run headless? At any rate, a PDS card can then become the startup screen in a clean break from Slot $E operations as opposed the the bastardized setup of the SE/30 hybrid? Dunno, food for thought and yet another hurdle on the road to straight up testing of the WireWrap1 prototype adapter.
Morning confuzzlement of the day: One of my old threads has resurfaced and reminded me that adapting the 68000 PDS to 020 PDS for Video is a done dea andl and I have an adapter in hand for taking a whack at adapting an LC PDS NIC to Plus/SE/Classic:
@Bolle has already explained probable function of the GAL on the adapter to make this possible.
< Tangent >
So the SE/30 appears to be hitting on internal video to display the :huh: icon at startup before INITs load and even before the Video ROM is polled? That makes sense regarding its odd designation. From my read, it's not a Declaration ROM per se in terms of the Slot Manager, being either a subset (superset?) of DeclROM function? This makes sense as the SE/30 sits at the fork in the road of Compact Mac development:
The SE/30 can be seen as a Color QuickDraw/NuBus architecture PDS hybrid from IIcs Sire and SE QuickdDaw PDS dam. The Classic, which is assumed to be the replacement the SE/30 in hardware comparisons, can then be seen as its purebred sibling, being a direct developed of the Compact Mac line that lived on for a bit in the Classic II The Color Classic in its bloated Compact form factor would be the SE/30's badly malformed offspring.
< Tangent >
