OK. I missed the cards from Israel. Because they have the sil3112 chip, is it theoretically possible to flash them so that one could boot to OS 0 as well as OSX?However, before looking at IDE, I"d go back on ebay and search "sil3112" once more because I did and found two different cards. Both should be flashable to work in Macs. They ship from Israel, so it's worth looking a little further afield, but it's not strictly speaking entirely impossible to find that card if you want it.
That was precisely my point, there are tradeoffs in everything about computing. Disk intensive applications can make a solid state upgrade make a computer seem to fly as in some operations with big files in Photoshop, but when it comes to applying filters you're still CPU bound. You won't see a lot of overall improvement in anything but snappier load times for mundane tasks.Absolutely, but that's not compute speed, that's disk read/write speed and random seeks are critical for that.
Perhaps. However, IDE and the G3 are being brought up because OP has been working on a cluster of threads fixing up this machine for use as a bridge Mac.I thought he was inviting a general discussion about how disk I/O changes might play out,
I largely agree - day-to-day on most things Quadra and newer with their stock disks is "fine". SSDs or CF and SD can improve a few different things.I can only think of a few situations where disk I/O is a problem on anything post-Nubus, post Mac II and Quadra era Apple hardware
I'll be perfectly honest: I don't usually think about this, mostly because I almost never actually intentionally bother to max out my systems, but it would be a good brute-force workaround to a situation where you're running an older version of $PROGRAM that expects to be able to use a disk directly as a cache spot.you can solve most every disk I/O problem cheaply and efficiently with RAM DISK.
In that cluster he also mentioned that one of his goals is to play around in OS9, hence discussing overall system performance outside the realm of setting up a dedicated bridge machine. I believe that requirement was in response to our discussing his question about the last/most recent machine that supported OS9. Since playing around in OS9 on the latest G4 machines that will run it is my thing, my advice in that even for his B&W might be appreciated for such. [Perhaps. However, IDE and the G3 are being brought up because OP has been working on a cluster of threads fixing up this machine for use as a bridge Mac.
And I appreciate that about you.I make no assumptions about what anyone is doing with their collections.
This goes both ways. My frustration with this set of threads and ones like it is that the posters involved usually have the appearance of asking for advice, getting it, and then not wanting to follow the advice. Especially because the original request pertained essentially to needing a bridge mac, and things related to getting that Mac running.I suspect folks are trying to help. But I wish people would just understand that I am interested in learning, and this is a hobby of mine.
So true Trash. I think the B&W will run 9.2.2 just fine. And at some point, the B&W willl get a Yikes! motherboard update with a 500Mhz CPU (Less then $20 from Hong Kong). And as a added bonus, I can install a flavor of OSX and learn about that. Will the fun ever stop??!! I am a happy camper.Since playing around in OS9 on the latest G4 machines that will run it is my thing, my advice in that even for his B&W might be appreciated for such. []
No worries my friend. You have taken great pains to explaine in detail things that my small brain was unable to wrap my head around. I am much obliged. You and I both like to run benchmark software. I will post my results as soon as I can.My apologies if I've created any confusion, made it more difficult to get access to the information you need, slowed progress, or anything of that nature. It certainly wasn't my intent.
I shall +1 to this because I think this would help clarify some things. There's a point to which this is clearly fleacore , the act of buying up someone else's eBay junk and seeing what helps, what doesn't, to make art. I do really dig that spirit.I think if you start a new topic summarizing your intent for this Bridge/Learning Tool Build with links to all your various investigative threads it would clarify matters and be quite helpful to others on both sides of your inquiry.
Love it! Substitute expansion cards of every sort, overclocking thingamabobs and accelerators in this world for the musical bent of that author and that's it!I shall +1 to this because I think this would help clarify some things. There's a point to which this is clearly fleacore , the act of buying up someone else's eBay junk and seeing what helps, what doesn't, to make art. I do really dig that spirit.
These cards now cost more than synthesisers actually built around the cards, which means people rip them out of fully working keyboards! This makes the whole thing batshit crazy, and I thought OK – let’s make finding fleacore built around these cards the next challenge.
At one time I used my MDD with eyeTV to record and watch TV. Then my MDD died and I wasn’t in the best financial condition to replace it. The Elgato manual said I needed a minimum of a G4 and USB 2.0. Didn’t have it but I had a B&W G3 with a 1.1ghz upgrade and a USB 2.0 card. That worked out very wellPoint well taken nglevin...
I saw a video on You Tube where a fellow paid a ton of money to buy a 1Ghz processor for his B&W. I thought it was madness. But having said that, I do like to see what speed I can squeeze out of my older hardware and software. I enjoy reducing the temperature in a computer and I enjoy speeding them up. I found a 500Mhz G4 processor for under $20.00. That works for me. My Yikes! motherboard cost me under $20.00. I will see what I can do with it.
My non computer friends thought I was nuts spending so much time converting my Color Classic to a Mystic. But it was quite fun and I leaned a lot. I am so new to 9.2.2 and OSX. And G3 and G4 hardware is also new to me. I am enjoying the ride.
I will try to start a new thread.
mraroid
