I use a SE/30 (with an internal SCSI2SD) and an extern 800 KB disk drive to produce floppy disks for 400/800kb drives. The SE/30 has a network card and can download software from the internet.
Before I had the network card, I used HFVExplorer under Windows to produce 1,4MB disk with my old Windows PC. They could be read by the SE/30 and then copied to the external 800kb drive.
Old disk drives should be cleaned and lubricated! But some drives do not work even after that...
Would re-writing a non-functional floppy with the original data be a good fix? Because a system disk I have says “Macintosh Sustem Tools Version 6.0.3” and it’s currently the only disk not working. Recently,
my Mac Plus’s screen started to be flaky and now is dark. Iirr I heat up the solder joints on the flyback till they melt, then let them settle again.
It might. I have had success in the past rewriting an image onto a disk that developed an error. I am sure it is fine but I am on the paranoid side so I usually make a backup to use and not rely on the rewritten disk.
Meh, the internal drive is giving me too much trouble. I’m probably going to get another and store the one I have now. I’ve had luck with Herb’s Mac Stuff, all of it works well.
Anyone want a tan Mac Kensington System Saver? I’m trying to get a grey one.
I just got my Floppy Emu in the mail today and am trying to do afresh System 6.0.8 install but I’ve run into a problem. When I get to the installation program I try to install but I get this error message:
