This is the 21st century... If it sounds too stupid to be done, there is every chance somebody has done it! lolare you suggesting they blew them some other way besides hot swapping? (Urinating on the port? Probing it with a bent paperclip?)
I explained the exact mechanism that blows the fuse. It's simple physics.Exactly. You have no idea what caused that fuse to blow... so using it against me to make your conspiracy is moot.
people do stupid crap, but hot plugging ADB is not one of them.
Here's a link to an ADB 4 way switch currently available on eBay. http://www.ebay.com.au/ulk/itm/252153542078No, ADB's not hot swappable per the spec. It's a maybe you can do it without damage, but really should not. That said, mechanical the KVM switches do it, but the rotary switch likely reduces the chance of damage significantly over hot plugging ADB manually.BTW: Peripherals would be the forum of choice.
