not sure what "massa" is. that would sort of label what it is. But from a quick eyeball, its a +12V regulator.
Thanks for the link, but I think the best solution is to see another tdk 699-0153....The badcaps forum (what a funny name :beige: ) has a board dedicated to PSU troubleshooting and repair. You could ask there if they can identify that mysterious component. There are several people around there skilled in the art...
Well, if you can get a replacement PSU of the same type for little money, go ahead! If not, it's worth trying to fix the existing one as I did with my old Astec PSU (still working after been fixed). BTW, a quick ebay search reveals a used TDK 699-0153 for 79,95 € + shipping from Germany to Italy. I bet the fix is cheaper...Thanks for the link, but I think the best solution is to see another tdk 699-0153....
On the pcb is marked as diode... you can shot a photo of the entire pcb?I agree. That PS has very much the same layout & design as the Sony PS in my HD20 SC I recently worked on.
Here's an image of the corresponding components in the Sony PS. Also apparently unmarked.
Yes, they are not exactly the same. My point was I agreed with Techknight's observation that your mystery component looks like a dual diode.Seems to be very different
