LC TDK PSU issues
Solved! Is a thyristor ;-)
31189756_10213411285851290_106760294134448128_n.jpg.2ff48c8e208a1be5a82e925573d2b223.jpg
Hi, I have this same PSU and I think this component is bad. When I turn it on, it clicks (indicating overcurrent, it runs for 9ms and stays off for 95ms). The -5V line seems good (charges and discharges with the pulses). The +5 and +12 lines though, have the same waveform on an oscilloscope: A flat line with slightly higher voltage on the pulses (600mV-off time, 800mV-on time). This suggests that the overcurrent is happening in one of these lines.
As this component gets quite hot, I am identifying it as the culprit. But I have a few questions:
What's a thyristor doing in a PSU?
Were you successful in replacing it?
