LC TDK PSU issues
Jon183
Hi everyone,
I have a TDK supply that has a really strong burning smell and gunk all over. I am going to send off for all the caps on the right side on Friday and give it a thorough clean. Just wondering if there is an issue with CR4 and what part it is, the smell seems to come from that part.
i think it is a zener diode, and if its heating up its shorted.
If it is shorted, then there has to be a reason why. if the power supply doesnt work, then the mitsubishi PWM IC is probably dead with it.
The system is lifeless and does nothing at all when switched on with this supply, have to share my good astec one between my LC and LC475.
Macintosh LC TDK 699-0153 recap list:
C5
180μF 385V
C8
8.2μF 50V
C60
47μF 25V
C55, C52, C51
1000μF 10V
C56
56μF 25V
C54, C53
270μF 25V
C64
270μF 10V
Pretty sure its accurate, haven't really double checked it though.
I have recaped my psu but random work or not... anyone know the code of the component IC55? Is at left of diodes... my component not have any word on it!
This is under red cross
Its a voltage regulator. Without xray vision I dont know which.
Easiest way to find out is measure it for shorts first, if there are none, then attempt to power on the supply and measure the input vs output voltage. thats how you tell if its bad or not.
Can be a CT7912? Positive or negative? ....the old component is destroyed, I tested it same as thyristor and is died...
