I have a slot-loading SCSI Pioneer DVD-ROM connected to my Performa 475. I'll see if I can get it to work under System 7 tonight and if that works, I can send you the relevant extensions by e-mail.
Oh I was only emotional thinking my drive is defective when in fact it is mint condition and nothing wrong with it. Plus, I find it hot to know it is literally designed to read only DVDNo need for dramatic caps lock. Finding a SCSI CD drive is thankfully still relatively easy. NEC Multispin drives have dedicated Mac drivers and my Plextor drives seemed to work fine with the "universal" Apple CD extensions and CD Sunrise.
Hi all,Hi xboxown,
I have just been doing some testing.
I installed FWB's CD-ROM Toolkit onto Mac OS 8.6 on my Beige G3. I copied the installed files onto a zip disk and tried it on System 7.1.1 on my Performa 475. I copied the CD-ROM Toolkit Extension (v4.0.1) and the Apple CD/DVD Driver (v1.2.2) into the Extensions folder, SCSI Probe 4.3 into the Control Panels folder and the CD drive files that come with the CD-ROM Toolkit into the System Folder.
Restart and It works.
The CDs in the slot-loading Pioneer DVD-ROM drive and in the Yamaha CRW8824S are both recognised under System 7.1.
When the CD is not in the mac during boot-up, I need SCSI Probe 4.3 to mount it. I can boot too from the Mac OS 7.6.1 installer CD in the Pioneer DVD drive.
If you can't use your Pioneer DVR drive, that's a shame. The advice given above is good. Get your a good external SCSI drive, or even a good internal drive and a SCSI enclosure. Yamaha, Plextor, Pioneer amongst others had good reputations then although I would expect that any SCSI drive from before 2001-ish will. I personally prefer the Yamaha CD-burners but whether a burner would be of any use to you is for you to decide.
Shall I put all of the files in question into a StuffIt 4 sea (self-extracting archive) or sit (ordinary archive) for you? I can put it onto the Macintosh Garden or e-mail it to you directly. If you'd prefer the latter, please PM me an e-mail address.
HTH,
aa
