I seen this on Craigslist for $10 and just had to have it. For those of you who don't know, Marathon Computer was a company who made rack mount things for Apple computers. Whether rack ears for your Powermac G4 or an entire case for your 9600. In this case, a 1U rack chassis for an iMac G3 DV logic board. This one's 500 MHz, out of a Snow White based on the order number.
The front is pretty unassuming. No fancy "PowerPC" or anything, just the ports, a slot and a Marathon badge.
From the back you get all the ports an iMac G3 DV had. The ports on the far left are to be linked over to the ones on the right if you want the front panel ports to work. Otherwise, leave them disconnected and you won't have front panel ports but you'll keep all the ones on the rear.
A view from the top shows just how sketchy these things are. There is no attempt at cable management by design. The board is just thrown in at a weird angle (to make ports line up), VGA port ribbon kind of wedged between boards, etc.
The ram is installed on a pair of right angle adapters. Without these the ram sticks up too high and fouls the top.
The biggest weird thing is this board. It's marked fan control, but I'll be damned if I know what that's about. It has the connections for the speaker and the power button/LED and then four 555s. What they do? Beats me.
Finally, know what's cooler than an iRack? How about two
