Hello,
My Mac II is not booting. From what I can see, one of the two 3V soldered batteries is dead. Who in hell even considered soldering batteries on a board! Anyway.
What would be the best way to repair change them? I looked on eBay, 3V batteries with holding tips are almost $40! way to expensive. I also saw a few cell battery holder that can be soldered on the board and I could install CR2032 to replace the dead battery. So far that's the better and cheaper solution I found.
Any other suggestion before I go any path?
Thanks
Thanks
