MacBottom breakthrough
Wow. I forgot just how flaky my current BasiliskII setup is...
There's definitely something screwed up with that disk image. Maybe it's just me, but I'm finding that every application that's on that disk appears to have some corruption in its resource forks. (Every application has a generic "pencil on paper" icon, and if you try to open anything you either get a "The application program "X" could not be opened, because an error of type -39 occurred" message, or a nonsensical message saying "There is not enough memory to open "X" (zero K needed, zero K available). To make more memory available, try quitting "".".  Interestingly some of the documents seem to retain at least part of their resource fork, because if you double-click on them they'll try opening the associated (broken) application.
This is definitely a job for someone with some deep arcane knowledge of MacOS filesystems.
Yea, my guess resource/data fork links or trees arnt right. Not sure.
Funny thing is, diskfit works. Lol. Neat little app.
Good news!
I think I may have found some drivers / utilities!
Go to http://vintageapplemac.com/154-classic-mac-survival-kit
And download:
http://vintageapplemac.com/files/misc/ClassicMacSurvivalKit.sit
Under Hardware, you will find:
MacBottom 800K.img.sit
MacBottom MFS.image.sit
I was able to convert the 800k file,
but not the MFS file.
…And I haven’t tested or used either one, yet.
If you still have your drive, let me know what your experience is.
It'll be a week and a half, before I get everything together, to give it a try..
If I get there first, I'll let you know.
Good luck!
--jim
Wow too bad it came a year too late.
I got rid of it after I knew I would never get it running again. And yet, here we are...
THIS is what turns me into a hoarder and not want to throw anything out! GRRRRR.
I did keep the MFM drive though just in case a HyperDrive unit fails as it fits.
That's too bad. I know how ya feel..
I guess it'll be there for the next person looking for it.
I'll still report whatever happens, when I get my MacBottom serial drive & 512kE together...
As a side note, have you guys compiled and installed the MFS Lives! filesystem extension for Mac OS X? I have it running. It's very useful; you can just double-click MFS disk images and they'll mount read-only.
