Hard Disk 20
IMG_20180127_100924266.jpgMore of a discovery than a conquest, but apparently at some point I acquired an HD20. Just found it in a box this morning. Seems to spin up (sounds like the drive spinning), but is not recognized by my Classic II. I think this might be the one my dad bought shortly after he got the 512k in 1984 and before he had it upgraded to a Plus.
You need to relube the stepper motor mechanism on the actual hard drive. Take the HD20 apart, remove the drive. On the underside you should be able to see a big square block with a shaft in the middle. That's the stepper motor. I bought some Hetman Nr 11 Rotor oil, but any kind of rotor oil should do fine... Squirt a couple of drops on the shaft. Reconnect everything (but don't secure the HD back in place just yet, you'll need to add more lube later). Power the drive up. Wait a minute or so until the driver finishes seeking and power it down. Rinse and repeat. (do not actually rinse the thing, but I think you see what I mean...). It probably won't work straight away, so be prepared to squirt some more oil onto that shaft. When it finally mounts on the desktop, secure everything down and you should be good to go.
Of course there is still a chance that even after all of this, it still doesn't wanna work... But I revived mine a couple of months ago and it worked well for a while. Now it doesn't though but I guess a couple more drops of oils should bring it back to life.
Oh and the Classic II is 100% compatible with the HD20. So it should work.
I have some lightweight synthetic air-tool oil that should probably work. I'll have to crack it open, clean out the 33 years of accumulated dust and see if I can bring it back to life.
I also discovered in another box what appears to be the Rodime drive from another HD20. Well, I guess it may not be from an HD20 as I'm sure that drive was used elsewhere.
Thanks for the walk through. I cleaned this out, lubed the motor, and this spun up and worked like new!
