Yay! I finally got one! SuperMac Thunder II GX
I saw a 13w3 cable at my local recycler, though I think it went to BNC and not VGA.  But I have a second spot to check for cables.
Well, with the right cable, any VGA capable monitor should be capable of monochrome VGA, right? Or does it actually have to be a monochrome VGA monitor? (I'm fairly unfamiliar with monochrome monitors of the VGA persuasion)
I think when the mono-only cable is connected to non-mono VGA, you get icky green shade.  It's been a while but the mono VGA pin shares the same video pin as green on color VGA displays.
Or maybe all 3 pins are tied the same and you get white display?
Dunno, but are you sure you're in the right thread? :)
Yeah, I think somehow my threads got crossed :-/ I blame the TBI and the pain meds... It's easier than admitting I'm not paying attention to where I'm responding...
Sorry about that.
Woohoo!  Man, I dunno.  Currently I have a tiny 1024x768 LCD connected.  I think I'll have to upgrade. :D  I'm sure I can find a 1600x1200 4:3 display at the recycler for relatively low cost.
That'd be my main display, a Dell whatchamacallit. Wide@$$ 1080p got nothin' on the table by comparison.
I figured on getting that reaction to the connector info, pigeonpigeongo! ;)
This'll be interesting.  Dunno if the SuperMac will be accelerated by my Radius Rockets, though.  There's a measurable difference in performance with my little red Radius when I have a Rocket installed.
Guess I'll have to try it out. :)
Dell UltraSharp MultiScan 20" rings a bell, it's a true 20" Image at 1600x1200. literally the largest 4:3 diagonal I've ever had the pleasure of using, matching even the ViewSonic P225fsitting next to it in size, if not in pixels.
IMO, you need to look for a 21" MultiSync CRT w/BNC in your outings, even if it's not 1600 capable. It's sounding to me like you're becoming almost as crazy a VidCard guy as I. Every Mac collector needs one and you need to grab one quickly, before they all disappear into the evil pit that is gaming consoles tucked away in "home theater" cloaked man-caves.
