gijsmans Posted March 6 Report Share Posted March 6 Could not resist a like new and complete Radius PowerView set like new from former Apple marketing guy. Only a PowerBook 140/170 or Classic II works says the documentation. Does anyone know if it works with other models as well? Quote Link to post Share on other sites
gijsmans Posted March 7 Author Report Share Posted March 7 Set up a LC I with system 7.1.2 and the Radius PowerView connected. It somehow works on the second screen, a 17” Dell LCD 1280x1024. It shows the Portait Display in the Dell ratio. Searching for a better monitor. So far so good. Quote Link to post Share on other sites
slomacuser Posted March 7 Report Share Posted March 7 Is this a SCSI connected Videocard? I would say it is slow for other than Word processing? Quote Link to post Share on other sites
naryasece Posted April 7 Report Share Posted April 7 Nice that you got it to work with an LC! I have a PowerView as well, haven't used it in ages but I recall getting it to work with a Classic II, PowerBook 180 and Duo 280c. I recall having to use the "I wish I were" control panel to get it to work with the Duo 280c, but I forget about the 180. Might have worked with the 180 without any change. I did not have any luck running it with a PowerPC machine (a 2300c). Quote Link to post Share on other sites
Recommended Posts
Join the conversation
