Jump to content
Mac SE, every so often brightness variation
Recommended Posts
My main-use SE has developed a curious issue. Every so often (maybe a few minutes), the screen will suddenly get noticeably brighter by a bit, then later, back down a tad bit darker to where it was before. It is not huge: I only noticed it when using the SE in a darker environment. However, it is noticeable, and it could be the harbinger of a larger issue in the future, so I want to nail it now. This machine has been fully re-capped, with a great CRT, and otherwise the screen works perfectly without any issues at all.
Ideas as to what might cause this?
Link to post
Share on other sites
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
