blusnowkitty Posted November 18, 2019 Report Share Posted November 18, 2019 (edited) Hey all, just wanted to gauge community interest to see if anyone would be interested in an ATX to Mac 10-pin adapter board. I've got a IIsi with a dead power supply (surface mount caps got REALLY bad inside) and @Compgeke and I have been working on an adapter board that'll take any ATX power supply and turn it into a 10-pin Mac supply for the compact II series, Quadra 650/700/800, Performa 600 and Powermac 7100 with full support for soft power. Right now I've got a batch of prototype boards being made to test out in my IIsi. Once we get that up and running, I'll start offering boards for sale if anyone's interested. Probably going to be sold as PCB only, kit, and fully assembled options. Will keep you up to date - if this works out, we may also work on an ATX adapter board for the II, IIx and IIfx that'll also solve the pesky startup battery issue those things have! Edited April 17, 2020 by Cory5412 updated title per request - coryw Quote Link to post Share on other sites
nglevin Posted November 18, 2019 Report Share Posted November 18, 2019 I am interested, having gone through at least three PSUs over the years. Quote Link to post Share on other sites
pcamen Posted November 18, 2019 Report Share Posted November 18, 2019 Definitely interested. Quote Link to post Share on other sites
JDW Posted November 19, 2019 Report Share Posted November 19, 2019 You're talking about a simple "cable/connector" adapter with one side plugging into the big connector on an ATX PSU and the other connector plugging into a Mac (including SE/30)? Quote Link to post Share on other sites
mattsoft Posted November 19, 2019 Report Share Posted November 19, 2019 It might be possible to design an all-internal solution using a Pico-PSU and simple AC-DC open frame PSU. I did one these a year or so ago for the Sharp X68000 and it works great and looks stock. Someone could easily adapt it for a Mac. Quote Link to post Share on other sites
Compgeke Posted November 19, 2019 Report Share Posted November 19, 2019 Nope, it's an actual PCB with an inverter for the /pfw line included on the board. A bit prettier than cable splicing and soft power will still be retained, rather than being hard on or off. You can buy the Molex connectors Apple used in a solderable package meaning assembly isn't too difficult. Even included a fan header so you can retain the cooling system needed, however how to mount that is a later problem (3D printed bracket or something that slides into the original mounting spot I guess). Combine with a PicoATX PSU and it'd be a reasonably pretty internal setup, providing you aren't running a bunch of nubus cards or a pile of big hard drives. The original PSU was designed for 5V 12A whereas your average picoatx will be closer to 8A. The only real "catch" is the -12V line is pathetic on most ATX PSUs, pico included, but to the best of my knowledge it's not used by much of anything except some nubus cards. It's only 1A on the factory PSUs anyway. I don't have a screenshot of the test board that's being produced right now, but here's an earlier screenshot. With any luck it'll fit the IIsi but some rearranging may be required with regards to overhang on the end. Some sort of support will also need to be figured out but that's easier once we have an assembled board with the connector to know what clearance is going to be under it, Quote Link to post Share on other sites
JDW Posted November 19, 2019 Report Share Posted November 19, 2019 -12V is used on the SE and SE/30, and I mentioned those machines because "pcamen" posted a link to this thread in our Modern PSU for the SE/30 thread. Quote Link to post Share on other sites
Byrd Posted November 19, 2019 Report Share Posted November 19, 2019 (edited) Yes, I'd be interested in a few bare DIY boards, if anything to have a known good PSU for testing Macs. You'd also have a good market for SE/30 boards if you decided to design. Edited November 19, 2019 by Byrd Quote Link to post Share on other sites
blusnowkitty Posted November 19, 2019 Author Report Share Posted November 19, 2019 While I wait for the boards to ship, I went and hooked up my IIsi straight to an ATX power supply. Turns out the IIsi doesn't really like it if you don't connect +5VSB; thankfully there doesn't seem to be any damage. Quote Link to post Share on other sites
Compgeke Posted November 21, 2019 Report Share Posted November 21, 2019 On 11/18/2019 at 6:23 PM, Byrd said: You'd also have a good market for SE/30 boards if you decided to design. So this one isn't quite as straight forward as the Mac II stuff is. It's mainly down to the requirement for the -12V rail and cabling to go from whatever is designed to the analog board. The first idea is to do something similar to the Artmix design and use an industrial PSU with custom cabling off that. This would be my preferred option really since it cuts $30-$40 off buying a Flex ATX PSU. The specs on the unit I'm looking at are 5V 12A, 12V 5A, -12V 1A. That would effectively double the output capacity of an original Sony Mac SE PSU while only being $35 for a PSU. I'd still need to crimp some stuff together for the actual harness and a fan connection, but it'd undercut the Artmix design by a lot. We're talking ~$60 in parts, however it would not be fansay inside a Mac SE PSU box. That'd be on you to supply. The other to do this would be to base it on a Seasonic or FSP Flex ATX PSU with a custom harness built. All three of those companies make power supplies with a male header on the power supply rather than built in cables. More or less the easiest way to do it would be invest in some minifit connectors and just remake a new harness, something that goes from the PSU's proprietary connector to the 10 pin Molex of the Mac SE power supply connection. I don't think there'd be much of an issue with needing to isolate a 12V rail for the sweep circuit, however if there is it isn't hard to hack a small inline PCB in that would just apply some extra filtering to the lines going to the sweep connection. Using these you don't have to worry about dealing with excess cable like you would with an adapter that plugs into a normal ATX end. Quote Link to post Share on other sites
Realitystorm Posted November 21, 2019 Report Share Posted November 21, 2019 (edited) Could something like this be used as a starting point? https://www.amazon.ca/COMeap-Adapter-Braided-Sleeved-Servers/dp/B06WV9Z9QT/ref=sr_1_3?keywords=24+Pin+to+10+Pin+ATX&qid=1574346237&s=electronics&sr=1-3 From what I can see the plug shapes seem right, it would be interesting if the wiring matches too. Edited November 21, 2019 by Realitystorm Quote Link to post Share on other sites
BadGoldEagle Posted November 21, 2019 Report Share Posted November 21, 2019 (edited) The main issue with modern PSUs is that they can't really output more than 20A on the 5V rail. The old 800 PSU could do 30A, and the Delta unit in the 9x0s could do 33A. I know they probably don't need all that power at all times except perhaps if you intend to use them as an old school server with more than 10 hard drives in them... but it's kinda difficult to know what the actual current draw is. I'd say it would be about 18A maximum to power the board and drives but I wouldn't feel very safe with a saturating cheap aliexpress PSU in my machine... For the Mac IIs or the Q650/700, modern ATX PSUs are still within the limits. Edited November 21, 2019 by BadGoldEagle Quote Link to post Share on other sites
Trash80toHP_Mini Posted November 21, 2019 Report Share Posted November 21, 2019 3 hours ago, Realitystorm said: From what I can see the plug shapes seem right, it would be interesting if the wiring matches too. Buying the extraction tool for the contacts in the connector and swapping the wiring around to match would be the way to go from what I've seen in the last couple of years. Surprised I hadn't seen that method before. 2 hours ago, BadGoldEagle said: The main issue with modern PSUs is that they can't really output more than 20A on the 5V rail. Aux 5V PSU should work, no? I've got a 300w FlexATX PSU slated for a IIsi can. A pair of them could be fitted into the IIcx form factor can as the absolutely worst case scenario, so adding an aux 5V power supply could be easily done? Quote Link to post Share on other sites
BadGoldEagle Posted November 21, 2019 Report Share Posted November 21, 2019 I've noticed that heavy duty aux. PSUs are rather heavy. I had found a 35A 5V industrial PSU but it weighted about two pounds... What kind of amperages can your FlexATX deliver? For a IIsi, power isn't a problem. Quote Link to post Share on other sites
68kMLA Supporter jessenator Posted November 21, 2019 68kMLA Supporter Report Share Posted November 21, 2019 (edited) I came across an analogous PSU replacement issue on Vogons and it lead me to this PSU—not sure if this is max or peak load, but 50A on +5 V, not too bad: https://www.ebay.com/itm/292609545791 Doesn't look ancient at any rate. So there are solutions, just extra digging required. Other SATA power to molex adapters might be in order, but still. Newegg (seller) link: https://www.newegg.com/p/1HU-01AD-001F4 Edited November 21, 2019 by jessenator Quote Link to post Share on other sites
68kMLA Supporter jessenator Posted November 21, 2019 68kMLA Supporter Report Share Posted November 21, 2019 well in my haste, I failed to take reviews into account. It's pretty bad… It's roughly 60/30 split between 1-star and 5-star respectively, with most complaints being failures. oh well, back to the search. Quote Link to post Share on other sites
Trash80toHP_Mini Posted November 21, 2019 Report Share Posted November 21, 2019 (edited) Dimensions are almost spot-on for inverting that Newegg PSU to replace the IIcx can. Bending a sheet metal wrap for that can on a box & pan brake would be easily done. Pop riveting or screwing it to side and back would yield mounting flanges, angle at back and all. Might need to do some surgery on the back side of the can to clear the snap? Dunno looks pretty good to the digiper readings for that. Dunno, worth a try anyway, the 3D model in my noggin looks pretty good. ___ | | | | | | | | | | | | |_______________________________________________ | Edited November 21, 2019 by Trash80toHP_Mini Quote Link to post Share on other sites
Trash80toHP_Mini Posted November 21, 2019 Report Share Posted November 21, 2019 4 minutes ago, jessenator said: well in my haste, I failed to take reviews into account. It's pretty bad… It's roughly 60/30 split between 1-star and 5-star respectively, with most complaints being failures. oh well, back to the search. Is that for eBay or Newegg? Can't imagine a Mac testing a 680W PSU to the point of borkage. Quote Link to post Share on other sites
68kMLA Supporter jessenator Posted November 21, 2019 68kMLA Supporter Report Share Posted November 21, 2019 (edited) 11 minutes ago, Trash80toHP_Mini said: Is that for eBay or Newegg? Can't imagine a Mac testing a 680W PSU to the point of borkage. Amazon (sorry should've posted link) Yeah, my PowerWave's SeaSonic was rated to 200W if that says anything. I doubt even a fully loaded Q950 would pull that, but that's not my wheelhouse. https://www.amazon.com/KENTEK-Supply-EPS12V-ATX12V-PCI-Express/dp/B006XJYVZW#customerReviews Yeah, who knows what systems they were building (saw one mATX), but if they were smart they wouldn't push it too far, so I'm guessing most systems would be 70–80% of the max load, so 500–550W system draws. That's my philosophy anyway—I don't want my max potential load anywhere near the max of the PSU. I think my Ryzen 2 rig pulls <600 W on my 750 W supply. But they aren't me I guess. Edit, I'm only pulling ~500W stock maybe my PSU was overkill. Edited November 21, 2019 by jessenator Quote Link to post Share on other sites
Trash80toHP_Mini Posted November 21, 2019 Report Share Posted November 21, 2019 Gamers. Quote Link to post Share on other sites
68kMLA Supporter jessenator Posted November 21, 2019 68kMLA Supporter Report Share Posted November 21, 2019 Yeah, looks like the failure point in a few of those is the PCIe power. That and the extra 4/8 ATX power pins aren't being used in this board adapter design anyway. Quote Link to post Share on other sites
Trash80toHP_Mini Posted November 21, 2019 Report Share Posted November 21, 2019 I wonder if technical drawings of that Newegg PSU's case are available anywhere? A cardboard mockup I can afford ATM, not the PSU. Quote Link to post Share on other sites
68kMLA Supporter trag Posted November 21, 2019 68kMLA Supporter Report Share Posted November 21, 2019 Modern supplies may be a little short on 5V current, but they usually have more than extra 12V capacity available. One could probably just use one or two of the affordable DC-DC switching "buck" converters available on Ebay to convert one of the 12V rails to 5V. The really cheap (~$1) ones only have a few amperes capacity, so carefully checking the conversion capacity of any DC-DC converter is important. Quote Link to post Share on other sites
Compgeke Posted November 22, 2019 Report Share Posted November 22, 2019 To be honest the main design goal isn't so much for the extreme 3 Radius Rockets + Thunder IV GX 1600 extra power consumption boxes but more for the regular 'old systems. Think a IIci with a random nubus video card and maybe ethernet. You can get picoatx PSUs with 8-10A 5V rails which'll cover that use case no problem, especially if you have a SCSI2SD rather than spinning rust. For more power you're best off going with a flex atx PSU which'll have significantly beefier rails, at the expense of being more difficult to mount inside the case without either drilling some holes in the back or hacking up a bracket. Said brackets wouldn't be particularly cheap on a small scale budget, whether 3D printed or bent metal or whatnot. I don't own a sheet metal brake or a 3D printer anyway. Quote Link to post Share on other sites
Trash80toHP_Mini Posted November 22, 2019 Report Share Posted November 22, 2019 @trag THX, forgot all about those things, Got a little one to go from 5V or 12V to 3.3V a few years ago. Took some measurements for the max size spec. of a drop-in ATX replacement for a IIcx form factor PSU: 150mm W, 140mm D, 86.5mm H A hair less might be better for Width and Depth in order to do a two sided mounting flange wrap. For that configuration, the fan needs to be on the top. Part out the original PSU, nibble a big hole for the fan on the bottom and your three sided, flanged wrap is ready made. with a notch on the corner of the hole, both mounting ears are retained for the power connector. I'd be tempted to nibble a hole in the exit grating on the back of the ATX PSU to match up with the louvered opening at the rear of the case to free up some airflow. Maybe not, the PSU will be idling at something like 20% to 40% max just to run anything with a PSU in that form factor. Quote Link to post Share on other sites
Recommended Posts
Join the conversation
