Jump to content
Daystar Universal PowerCache P33 in SE/30
Recommended Posts
Hi, I recently installed a Universal PowerCache in the SE/30 but the "PowerCache" portion doesn't seem to be doing anything.  Toggling "PowerMath" seems to increase or decrease performance in Speedometer, but toggling "PowerCache" seems to have no effect (with or without restarts) in between.  I've tried empty Control Panel and Extensions and that sort of thing.
Using Speedometer I'm getting around 9 for CPU when it should be around 12..
Running the DayStar PowerDemo shows the line "PowerCache external cache is disabled".  I can enable it through the menu, but it seems to do nothing, and once I put the Demo App in the background and come back it seems to toggle back to disabled automatically.
I'm running System 7.1, SE/30, stock rom.  Any thoughts?  Or could it be a broken PowerCache?
Thanks!
Link to post
Share on other sites
  • Replies 107
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
Darn outside of edit window.  Using a TwinSpark btw.  I have tried version 1.3, 2.0, and 2.2.  Control Panel is loaded, with some validation as PowerMath toggle works and affects the PowerStar demo and Speedometer.
Command-Control clicking the PowerCentral logo shows everything as it should as far as I can tell.
If you have one working, may I ask what behaviour is with Command-T, toggling the PowerCache and the status message is when you put the application in the background?
One more clue, this one did not come with an on-board FPU, socket is empty.  It shows 50mhz 68030 and 16mhz 68882 in the status window of PowerStar demo.
Edited by K Trueno
Link to post
I believe it is the Twinspark. I had a similar problem that the one you describe but with a P34 and a TwinSpark II, with and without the onboard FPU. I had no trouble using the same PowerCache in an IICX. Is the System stable after 10 minutes? Mine wasn’t.
Link to post
Hmm interesting!  As far as I can tell it was running stable for the duration I was testing it, but I was swapping around Control Panels/Extensions a lot and rebooting often.  I will give it a try again tonight.
Hopefully it is a software problem and not a hardware problem.  How does the PowerCache know to enable or disable the L1 cache on the card?  Does it look for for specific addresses and intercepts them before it goes out onto the bus?  Is that in SW or HW?
Any chance that an FPU is required for the L1 Cache to be enabled?
Link to post
  • 68kMLA Supporter
The cache is usually on by default. It will work without an FPU on the PowerCache.
All the cache logic is done in hardware. Actually I am not totally sure how it is enabled/disabled. Probably the software calls a specific address which flips a bit in one of the registered GALs.
Not sure if I have seen a 50MHz P34 yet, are you sure it is running at 50MHz? If so what are the speed ratings on the CPU and SRAM/Tag chips?
Link to post
Sorry, forgot to mention the P34 was 33MHz not 50MHz.
Link to post
To be fair, I'm only comparing numbers of Speedometer that I've seen from others/records file (~9 vs ~13) vs. my own accelerator, the PowerStar Demo status output (always says "external cache disabled"), and that the toggling the PowerCache toggle in the control panel has no effect on those numbers.
Does anyone know if the toggle work instantly btw?
Interesting.. thats probably it.  I noticed this in a patch for NetBSD for mac68k:
+inline void
+enable_daystar(void)
+	disable_daystar();
+	printf("Enabling DayStar External Cache...\n");
+	asm("tstb	0x52070000 | enable daystar external cache");
+	asm("tstb	0x52050000 | enable writeback cache");
+	flush_daystar();
Maybe going too deep.. but could a GAL fail?  The motherboard is recapped but not the PSU or Analog board too, could bad voltages leave the cache off?
Edited by K Trueno
Link to post
I think so, at least with the Turbo 040. I tried two different PSU:s for the P34, the Sony stock configuration with no re-cap, and then when I got desperate, I went off and bought the Enhanced Power Supply from Artmix. Made no difference for the cache part, but the screen looks great!
Link to post
  • 68kMLA Supporter
GALs can theoretically go bad but I am 99% sure your card won't work at all if one of the GALs was bad.
Score in Speedometer 3 is around 9-ish for me as well. PowerDemo behaves just like it does for you.
Enabling/Disabling the external cache doesn't change the CPU benchmark score in Speedometer either. That doesn't mean a lot though as long as we don't know what exactly that benchmark is doing.
The routine probably fits into the internal caches of the 030, so the external cache isn't even used.
Link to post
That would make sense.  Glad its not the hardware :-)
Cool thanks for confirming!   Maybe it is just how the Universal PowerCache behaves in an SE/30.
Because, from @JDW's video comment (Socketed PowerCache - "with Control Panel it goes to 11-13"),  and these posts about a DiimoCache (@50mhz):
It seems like it should be benching faster.  For example, this is my current Benchmark compared with a DiimoCache (@Knez):
Better than his original 0.87 yes, but 1.06 vs 2.38 is a big difference.  FPU does match his original which makes sense (0.14 ~= 0.16 matches since I don't have the FPU on the card).
Pretty interesting!  Funny trying to squeeze that last bit of performance out of a 16/50mhz machine :-D
Link to post
Your Speedometer 3 performance score of 9 is about what I get with my CPU-socketed version Daystar PowerCache 50 MHz accelerator when the Power Central control panel is NOT loaded at boot time. And by “socketed” I mean my accelerator connects to the CPU socket on the motherboard, and no Artmix adapter is required.
Low or unstable voltage should not have any affect on whether the cash is activated or deactivated. If anything, unstable voltage  causes freezes.
What version is your Artmix adapter?  I would say that part of the equation is suspect.  Have you contacted Manabu Sakai of ARTMIX about this problem?
Link to post
Ah yes the unobtainum socketed version (not jealous at all :-))
How does it bench with the Control Panel loaded at boot time say in these
scenarios:
  • PowerCache On, PowerMath On
  • PowerCache Off, PowerMath On
  • PowerCache On, PowerMath Off
  • PowerCache Off, PowerMath Off (I would assume 9 here)
I also wonder how PowerDemo behaves for you!
I have the blue one (looks like the one in your pictures in shape, but blue).  I had not thought about this as being a possible issue!
So, I happen to also have an original IIsi version of adaptor and tested it out, and I am getting the same results.
But perhaps I am overthinking it, could that last bit just having no FPU, and the PowerDemo thing a red herring (as it happens for @Bolle too?)
Link to post
Please post a nice photo of the FRONT and BACK of that PDS slot adapter.  I've not seen one before.  I've only scanned a photo of the Daystar version here:
Daystar Digital SE/30 Adapter
You also are forgetting the need to benchmark ENHANCED PowerMath, which I mention in the following thread (which I will benchmark for you later):
Link to post
Oh its nothing special, its the IIsi Daystar Adaptor.  I can still take pictures if you'd like!
I have tried that too, it does not affect the Processor benchmark in Speedometer.  Thank you for benchmarking in advance!
BTW, I tried the Command-Option clicking like you mentioned in the other thread, and it has no effect on my benchmarks!  So, while you say it degrades your performance, it makes no changes to mine, which leads me to believe that the cache portion of the PowerCache is not active, instead of the cache being on and the toggle being broken. :-(
Edited by K Trueno
Link to post
Speedometer 3 test variations are these:
  • PowerCache Off, PowerMath Off (same as if PowerCache control panel not loaded at boot time)
  • PowerCache On, Enhanced PowerMath On
  • PowerCache Off, Enhanced PowerMath On
Hold down Option & CMD keys while clicking on the PowerMatch switch in the control panel to enable Enhanced PowerMath, which will then be shown by "PowerMath" being underlined.
With PowerCache OFF I get about 9.5 in Speedometer, and with PowerCache ON I get 13.7.  And yes, I do see a boost in FPU performance for some operations with Enhanced PowerMath ON versus regular PowerMath ON.
I am still building Speedometer 3 Machine Records for you, which I will post in SIT format for you in a few days (sorry, I'm quite busy the next few days).  My disk tests will be slow because I booted off my FloppyEMU.  I even got a "FATAL ERROR" display on the FloppyEMU just now during disk testing for some unknown reason.  Anyway, I used my Micron Xceed Grayscale adapter to complete all the video tests.  In monochrome mode though, the Color30HR is only as fast as stock graphics.
I look forwarding to seeing your photos.
Link to post
Appreciate it!  Hoping to hear from others as well.
Below are some photos:
Link to post
Thank you for the photos.  Do you have the original documentation for it?  I'm curious if Daystar officially says it will work properly in the SE/30, or if it is intended only for the IIci.
Link to post
OK.  Below are my Speedometer 3 benchmark files (one file is v1.5.1 .sit and the other is the same .sit file but subsequently Binary encoded), with each benchmark saved in its own file.  When you view the filenames, please note:
PC = PowerCache
PM = PowerMath
EPM = Enhanced PowerMath
Speedometer3_JDW.sit
Speedometer3_JDW.sit.bin
Let me know if the SIT file is usable as-is.  Not sure if Binary encoded is needed when uploaded to this forum.
Link to post
Nope I do not I'm afraid.
Great I will try this out once I get home, thanks!
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
