Jump to content
Registered ECC SDRam in G3/G4 ?
Recommended Posts
Hello and Happy New Year to you guys !
Just wondering: do B&W G3s and pre-MDD G4s accept ECC Registered memory modules ?
I know that standard and registerd ram should'nt be mixed, but what if the G3/G4 ram banks are populated only with registered ecc ?
Cheers.
Link to post
Share on other sites
*Unregistered* ECC RAM might work in a G3/G4. Apple systems in general are "picky" about DIMMs (I've had really bad luck trying to use apparently perfectly good RAM pulled from Pentium IIIs and Athlon machines in my B&W G3) but the only difference between unregistered ECC and non-ECC DIMMs is the ECC DIMMs include an extra 8 data bits which the host system is free not to use. So if the system is otherwise OK with the specs and configuration EEPROM data of an ECC stick there's no reason a Mac won't work with it.
"Registered" RAM on the other hand actually has a buffer sitting on some of the control lines, and since its presence induces additional latency (while improving reliability) the memory controller actively needs to compensate for it. So far as I know no Macs which uses SDRAM supports it. I could be wrong, but I'm fairly sure that's the case.
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
