Lateralus Posted November 3, 2008 Report Share Posted November 3, 2008 Specs in my signature; Today, my CPU cards arrived in the mail and they were the last parts I was waiting on in order to make my 9600 operational again. But I seem to have problems getting a video signal. I've cut down to 1 stick of RAM, used in various slots, swapped out with other individual sticks of RAM. I've tried booting with and without the machine's ROM SIMM installed; with and without my SCSI PCI card installed; with and without my new 73GB SCSI attached, both to the on-board SCSI and the SCSI PCI... I know for a fact that the Radeon works fine. And I've tried switching it between different slots. I've hit the CUDA. And I tried to do a PRAM reset but the key combination doesn't take. I've tried my NewerTech MAXpowr 400MHz G3 and a NewerTech ZIF Carrier with a 350MHz CPU. Nothing is working. This thing worked when I stripped it and put it into the closet a year or so ago... Any suggestions? Quote Link to post Share on other sites
equill Posted November 3, 2008 Report Share Posted November 3, 2008 (edited) What form does 'problems getting a video signal' take? Do you get POST chime? Audible or palpable HDD spin-up? Raster, or not even that? The shorter card amongst the RAM slots is cache—not ROM—of which the cache on the card of a MAXpowr PDS or ZIF CPU should enable complete removal if it is smaller than that on the CPU card. Is your PRAM battery showing at least 3.3V in circuit? Removal of the 9600's ROM (if you could) would turn the 9600 into a kerbstone, anyway. Given that the MLB was demonstrably working a year ago, first impression is that you have a bad connector somewhere. The PDS slot is one that catches many people out because of the extra force needed to bottom a card in it. That failure should produce absolutely no activity of any kind. Is that what you get rather than just 'no video'? If not that as the cause, is the PSU giving you the green power-on LED? de Typo. corrected Edited November 3, 2008 by Guest Quote Link to post Share on other sites
Lateralus Posted November 3, 2008 Author Report Share Posted November 3, 2008 I'm getting chime, I'm getting hard drive spinup and activity, PRAM is 3.6v and the power button is going green. Quote Link to post Share on other sites
Gil Posted November 3, 2008 Report Share Posted November 3, 2008 PRAM doesn't take? As in, you do the key combination and it doesn't chime again? Take out the PRAM battery - I don't think any of my Macs have ever had a working PRAM battery. Quote Link to post Share on other sites
equill Posted November 3, 2008 Report Share Posted November 3, 2008 (edited) Since video resolution is a parameter that is often stored in PRAM, leaving the battery out is not a good blanket recommendation. It matters not in the case of many Macs, of course, but video cards are apt not to like having no clue about what to do with a display. That seems not to be Lateralus's problem, true, but failure of an apparently-ready Mac to boot needs systematic consideration of all possibilities. Lateralus: have you tried to reseat and bottom the PDS-style daughter cards? I take it that you are getting to raster, then, but not to on-screen pointer and mouse-tracking? The startup sequence is well-defined right through to the desktop, with quite specific 'milestones' such as those already mentioned. Where does your 9600 poop out, specifically? Regardless of the lack of accompanying sound (if that is so), does an attempt to reset PRAM give screen blanking after the appearance of raster? Keep in mind that swapping CPU cards in and out is a good time to be using the CUDA instead of the four-fingered salute as the last action before closing the case. The CUDA in a 9600 is indeed a CUDA rather than a PMU reset button, so it needs 20sec or so to be sure of clearing parameters. de Edited November 3, 2008 by Guest Quote Link to post Share on other sites
Lateralus Posted November 3, 2008 Author Report Share Posted November 3, 2008 (edited) Yes, I've worked the CPU cards in well enough. And it is chiming so I don't think the problem lies there. Specifically, I'm getting no video signal whatsoever. My display just remains asleep. And there's nothing wrong with the display. Power on > Chime > Hard drive spin-up > Hard drive activity > No video signal whatsoever PRAM doesn't take? As in, you do the key combination and it doesn't chime again? Bingo. Tried several times, too... Edited November 3, 2008 by Guest Quote Link to post Share on other sites
paws Posted November 3, 2008 Report Share Posted November 3, 2008 Had this on my G4, replaced the graphics card and it was right as rain. Quote Link to post Share on other sites
Lateralus Posted November 3, 2008 Author Report Share Posted November 3, 2008 I'd normally be assuming the Radeon was the culprit as well. But I just tested it in a friend's Power Mac G4 yesterday. Drats. Quote Link to post Share on other sites
equill Posted November 3, 2008 Report Share Posted November 3, 2008 If you are sure of the video card, you seem to be left with the inconvenient truth that a poor connection, either physical or logical, is at work. Is the video cable to the display known-good? Is the video-out connector clean and bright? Is the brightness control of the monitor (if there is a physical control) at minimum? Is the display working? Is the display compatible with the Radeon? Is the Radeon software on the drive(s)? (Yes. Even without it you should get something.) As the man-on-the-spot you are infinitely more able to check and recheck every rational or irrational possibility, all the while hoping that it is not something unexpected and overlooked that is having effect. Your problem is unusual, especially with a 9600, but even something as way out as having no ground connection in your mains cable could play a part. Best of luck, and keep us posted. de Quote Link to post Share on other sites
equill Posted November 3, 2008 Report Share Posted November 3, 2008 PS: I don't know the 7200 because I use a 7000 with DVI-I out and a Kansas board in my 9600s. A thought, though. Is the 7200 compatible with a Tsunami board as in a 9600/200? Have you set the DIP switches on the CPU cards to accord with Tsunami rather than Kansas? de Quote Link to post Share on other sites
Lateralus Posted November 4, 2008 Author Report Share Posted November 4, 2008 The video cable is fine. The monitor is fine. The video connector is fine. The display is VGA and I'm using the VGA on the card. The hard drive is blank, but it shouldn't stop me from getting a signal. And it's a plain old Radeon Mac Edition, I just call it a 7200 as ATi renamed it such upon the release of the 7000, and numerous people have used them in 9600s. I have the switch settings for neither of the cards, but I wasn't aware a non-carrier required special settings for a six-slot machine. Quote Link to post Share on other sites
equill Posted November 4, 2008 Report Share Posted November 4, 2008 For daughter cards used with Kansas MLBs, the DIP switches must be set to ON-OFF-OFF-ON, so labelled on the DIP, or closed-open-open-closed if labelled that way. If your source for the card was someone using the card in an 8600/300, a 9600/300 or a 9600/350, that configuration may persist, but for a Tsunami MLB it must be OFF-OFF-OFF-OFF. You write as if you are familiar with a ZIF Carrier Card, so I shall not list the three DIPs for the NewerTech card (as opposed to the two DIPs for an Apple card), but note that a 350MHz card is Apple-designed. The NewerTech card has a 330 or 366MHz ZIF rather than a 350MHz. de Quote Link to post Share on other sites
Lateralus Posted November 4, 2008 Author Report Share Posted November 4, 2008 The MAXpowr is a 400MHz G3 and the Carrier has an Apple OEM 350MHz G3 ZIF. I've set the MAXpowr to on-off-off-on, as well as other settings, but the machine wont even chime with it installed and hasn't yet. But I still get HD activity. The Carrier, I've set using this. This card always gives me a chime, but still wont give me video. Quote Link to post Share on other sites
equill Posted November 4, 2008 Report Share Posted November 4, 2008 OK. So you need a wider net/bigger hammer. It's RAM time. The 9600 can use FPM or EDO RAM, but not both at once, whereas the 9500 uses FPM only. I guess that you have three 128MB cards and a 16MB card. Retire the 16MB card, and put any other unpairable cards (one 128MB?) aside during testing. Be sure that the others are all of a kind (FPM or EDO) and pairable. RAM in the x500 and x600 (x= 8 or 9) should be paired (for interleaving), working downwards from A6/B6 towards A1/B1. No guarantee that this is the present cause of trouble, but it could be. I saved a 9500 from massage with a hammer by removing a supposedly harmless unpaired card. That same NewerTech manual that you linked to has the gen about the fixed-processor DIP settings. I take it that the MaxPOWR Control Panel and extension are accessible to you, even though not installed on the HDD yet? Getting your HDD initialized and installed with OS 8.6 or 9.1, or 9.2.2 with the help of OS9Helper, will make that software available to the CPU and assist your search for the Desktop. de Quote Link to post Share on other sites
Lateralus Posted November 4, 2008 Author Report Share Posted November 4, 2008 I've already played the RAM game; I've cut down to 1 stick of RAM, used in various slots, swapped out with other individual sticks of RAM. And I have no way to install anything on this hard drive until I get video. Quote Link to post Share on other sites
Lateralus Posted November 13, 2008 Author Report Share Posted November 13, 2008 Hmm... Interesting development. I decided to fiddle around with the machine again today; I reset the CUDA a few times, and eventually wound up moving the Radeon to slot D2. And... presto! Sorta. I now get chime and video signal, but the signal is lost within a second or so and my monitor goes back into Standby before it has a chance to actually display anything. I've only got one stick of RAM in at a time (and I've used several different sticks), the Radeon is the only PCI card, and I've got an XLR8 Carrier in now set to the proper settings. I've also tried three different PRAM batteries, and none of them get me past the signal-flash. And if I move the Radeon out of D2, I'm back to where I was before; chime, but no video signal whatsoever. Thoughts? Quote Link to post Share on other sites
equill Posted November 13, 2008 Report Share Posted November 13, 2008 Briefly, give yourself a stable point from which to depart and to which to return. Remove all of your potential upgrades and reinstall a minimal configuration of the original cards, processor and RAM. Reset the MLB. Get the whole to boot and show the HDD. Prepare the HDD, install a workable OS, and include extensions and CPs that will be needed for the upgrade. Make sure that this gives you a stable working machine. Then only begin your upgrades, in the order processor, RAM, video, other cards, one at a time, resetting the MLB after every configuration-change, and assuring yourself of the stability of each new configuration before you proceed to the next. Only thus will you be able to recognize and repair either glaring or subtle faults, and disabilities of configuration that prevent you from reaching your intended destination. Don't abandon any diagnostic procedure because it failed at a single attempt. A known-good external SCSI startup volume will be of inestimable value during the process. This would have been your best course all along. 'You don't ever know where you're arriving at unless you know where you came from.' de Quote Link to post Share on other sites
Lateralus Posted November 14, 2008 Author Report Share Posted November 14, 2008 No offense, but I get the impression you're not reading my posts. I've made it clear since my original post that I'm running with a minimum hardware configuration and have been from the start. I've also made it clear that I'm not getting a video signal; it is, in fact, the entire reason for this thread. If I had a video signal, I would have already installed an OS. And if the machine were operable enough to allow me to boot from CDs, format hard drives and install operating systems... this thread would not exist. Quote Link to post Share on other sites
Kami Posted November 14, 2008 Report Share Posted November 14, 2008 Its not clear to me if you've installed the - original CPU - original hard drive or small capacity SCSI on the SCSI-1 chain in the bare system. I'm also not clear if you've actually tried to boot from the internal CD-ROM drive using an OS 9 CD-ROM I'm also trying to remember if your Mac Radeon card required any extensions to be installed Have you tried SCSI disk mode from your 3400 to the 9600? This is making me want to pull out my 9600 Quote Link to post Share on other sites
Lateralus Posted November 14, 2008 Author Report Share Posted November 14, 2008 The original CPU is long gone. I also don't have the original hard drive and in fact don't have one installed at the moment. And I'm using the stock Apple SCSI CD-ROM. Hadn't thought to try blind booting from a disc yet though. May have to try that tomorrow. And I've been through more video cards than I could ever count, and I don't recall ever seeing one that requires the OS to load an extension/driver before giving even a low-res signal. Don't have the original video card, either. But if I had another running machine that would allow me to install OS 9 and the Radeon driver/extension on a drive, I'd definitely give it a shot. I threw out so much Mac stuff last year, thinking I wouldn't even need any of it again. Drats. SCSI disk mode isn't a bad idea either. But unfortunately there seems to be a sickness that has taken out both my 3400 and 9600. I'm still just boggled as to why the system now gives me a video signal, but only for a second after powering on. And the PRAM zap keyboard command still wont take, either. Quote Link to post Share on other sites
coius Posted November 14, 2008 Report Share Posted November 14, 2008 I would like to chime in because I had the "No Video" problem with a Beige G3 as well as a 7300. The main issue I had was that the radeon wouldn't output video, but the internal one may. It I got it loaded into the system and fiddled around with the video settings using the internal video and then rebooting and taking off the internal video display, I was able to get the Radeon 7000 that I had to work. you *may* need to source and original card. Mainly as the one apple sent with the machines were specifically coded by Apple. Hence the reason why people didn't have this issue when they got it out of the box. I happen to have a PCI 2MB Mach64 Card that came out of a 9500. I am going to be shipping some stuff soon. If you send $14 my way, I will gladly ship it out (That includes shipping) I basically want $10 for the card, and padding the $4 for shipping. If it uses less than $4 for shipping, I will gladly return the remainder of the $4. I will accept $$ through paypal, but I will have to let you know when I can ship stuff out. Should be next week (that also goes for JRL and whatnot that I am dealing with now also) Quote Link to post Share on other sites
Kami Posted November 14, 2008 Report Share Posted November 14, 2008 I am going to pull out my 9600 tomorrow and try a few things to see if I can help out a bit further with this problem Quote Link to post Share on other sites
Gil Posted November 14, 2008 Report Share Posted November 14, 2008 Sorry to hijack Lateralus' thread, but I'm getting almost identical problems on my 9500 now. I have a Sonnet G3 300 MHz upgrade, as well as original 604e 150 processor. I also have the original ATI Mach64 card, as well as my flashed Voodoo3 PCI card. Nothing works! I can get chime, sometimes PRAM doesnt take, haard drive activity. With the Mach64, I get a pink raster with a cursor, nothing happens. CUDA reset doesnt help. Please help! Quote Link to post Share on other sites
madmax_2069 Posted November 15, 2008 Report Share Posted November 15, 2008 i wonder if a failing PSU could cause this ? does everthing on the motgherboard look good like the caps and other. its to bad you no longer have the orignal hardware, i find its always good to keep the orignal CPU (if its good) Video card (if it came with one), and ram (if its good) just for these issues you are having now, just so you could test. Quote Link to post Share on other sites
Kami Posted November 15, 2008 Report Share Posted November 15, 2008 OK, I pulled out the 9600 after a year of it sitting under a desk. I'd forgotten how big and how heavy the beast was. My 9600 has the original video card and Mac Radeon 7000 with DVI/VGA/S-Video. Plugged in USB mouse and attached it to Samsung LCD via VGA.It powered up fine, chimed, and SCSI drives spun up correctly. Screen flickered. But... no video. I kid you not. Now I'm pissed off. Since I couldn't remember which video card was for the start up monitor I tried all combinations of adapters (Mac DB-15 -> VGA, DVI->VGA). The it dawned on me. The Samsung is a widescreen display. I hauled the beast back across the house to where I have a non-widescreen display. Plugged everything back in. Powered on and the screen flickered and went blank. Still no display. After saying a few choice words, I opened the case and pulled the Radeon out. Reset the PRAM 3 times. Plugged the DB-15 to VGA adapter in and started up. Success. Full colour and the desktop all there So, now the big question is what type of display are you plugging into? Also have you pulled the battery and left it out for any length of time? Quote Link to post Share on other sites
Recommended Posts
Join the conversation
