Pinstripes Posted December 26, 2007 Report Share Posted December 26, 2007 My eMate's battery doesn't really hold a charge anymore. I've heard of people using regular AAs instead ... how does one go about doing that? Quote Link to post Share on other sites
Anonymous Freak Posted December 26, 2007 Report Share Posted December 26, 2007 Here you go: link Quote Link to post Share on other sites
Pinstripes Posted December 26, 2007 Author Report Share Posted December 26, 2007 Ah, great. Do you think this is possible with off-the-shelf rechargeable batteries and by someone who has no soldering experience? Quote Link to post Share on other sites
Kallikak Posted December 26, 2007 Report Share Posted December 26, 2007 Yes. The only thing is make sure you remember the polarity of anything you remove. Quote Link to post Share on other sites
Quadraman Posted December 26, 2007 Report Share Posted December 26, 2007 Ah, great. Do you think this is possible with off-the-shelf rechargeable batteries and by someone who has no soldering experience? I have seen people using off the shelf rechargeables with the built in charger in the emate. Quote Link to post Share on other sites
MacMan Posted December 26, 2007 Report Share Posted December 26, 2007 The best way to do it is buy a long 4xAA battery holder (2x2 batteries, lengthways) from an electronics shop / website and transfer the old battery pack connector onto it. You don't even need to solder the wires, it is possible to use butt connectors or even simply twist them together and tape them. Then you can put NiMH AAs in and remove / change them whenever you wish. Much easier than fiddling about with soldering batteries together. Note: you will probably need to lengthen the eMate's battery compartment a little by trimming off one of the plastic ends. It's pretty easy to do and doesn't affect the eMate's appearance at all, since it is an internal modification. Here's a link to a pic of this setup that I made on my eMate: With the 2700MAh cells I installed, my eMate can run for 30+ hours on a single charge! Quote Link to post Share on other sites
Kallikak Posted December 26, 2007 Report Share Posted December 26, 2007 If you get rechargeables with solder tabs, the soldering doesn't really involve any mucking about. I certainly prefer that to cutting the plastic. Quote Link to post Share on other sites
30pin Posted January 10, 2008 Report Share Posted January 10, 2008 One thing I am not clear on, is if you can still use the original Newton 9w power adapter? It's output is 7.5v -1.2amps. All the rechargable batteries seem to be 1.2v ? Or do you get one of the 4pack rechargers and take the batteries out of the emate everytime they need to be charged?? Quote Link to post Share on other sites
MacMan Posted January 12, 2008 Report Share Posted January 12, 2008 One thing I am not clear on, is if you can still use the original Newton 9w power adapter? It's output is 7.5v -1.2amps. All the rechargable batteries seem to be 1.2v ? Or do you get one of the 4pack rechargers and take the batteries out of the emate everytime they need to be charged?? I still use the Newton charger and it works fine. The first time I charged my home-made battery pack I kept a close eye on the temperature and it stayed at the normal level for a charging battery. Quote Link to post Share on other sites
30pin Posted January 13, 2008 Report Share Posted January 13, 2008 Thanks Macman! That was what I needed to know!! Quote Link to post Share on other sites
Recommended Posts
Join the conversation
