Jump to content
ADB Busboy: Adapter for USB peripherals over ADB
Recommended Posts
Presumably the obvious solution for using these in a KVM configuration would be to just buy one for each Mac and use a VGA+USB (with the aprops Mac to VGA adapters on the video side) KVM, which shouldn't be particularly difficult to find. Sort of lost the plot when you started talking about mixing an EKII and a (USB?) laser mouse at the driver's seat, though.
Link to post
Share on other sites
  • Replies 111
  • Created
  • Last Reply
Top Posters In This Topic
I was just wishfully thinking. If I could have a KVM into which I could plug USB and ADB devices and still have ADB functionality (especially booting from the keyboard!), I would be very happy.
If you want a KVM to control 4 macs with ADB, a USB KVM with lots of iMates is an expensive proposition nowadays and you can't boot from a USB keyboard.
If there were an ADB KVM that allowed USB & ADB inputs, then I could plug in my EKII int, my laser mouse and still control my x number of macs.
Link to post
  • 2 weeks later...
Could you elaborate? Do you mean adding more ADB ports to share the USB peripherals between several Macs?
No. What I would like to know is can I use a standard usb kvm. Usually it has a built in hub and only provides usb keyboard and mouse over one usb cable. Like if I wanted to integrate an adb mac, say a Quadra 700, into my existing kvm setup. Thanks!
Edited by gobabushka
Link to post
  • 2 weeks later...
  • 3 weeks later...
  • 68kMLA Supporter
I've put a considerable amount of dumpster-diving effort and money into securing a lifetime supply of Apple Extended Keyboard II's - to me, the AEKII is the best keyboard ever made. That being said, having the option to use more modern USB input devices with all my retro ADB-equipped gear would be a fun and unexpected option - I'm definitely down to buy one of your adapters when it's ready!
Link to post
I only just came across your project and this is something I've been wanting for a while. There are a few projects for the opposite sort of adapter but few that turn a USB keyboard into an ADB one.
Firstly, can your adapter handle 'combo' keyboard & mouse/trackpad style models? That's the type I would likely want to use (something small and combined to easily test my Macs with).
Secondly, I might be a bit late in replying if you've already designed the PCB, but would it be possible to have a USB keyboard with a media 'Power' key trigger the ADB power button instead of having to physically press that button on the PCB? Quite a few keyboards have that key (as well as the USB Mac models).
Finally, I would love to have a way to at least use some media key functionality under early MacOS. The Apple Adjustable Keyboard had 'Volume Up', 'Volume Down', 'Mute' and a 'Mic' button which doesn't really have a modern equivalent and could possibly be mapped to Play/Home/Browser/whatever.
TMK has documented these multimedia keycodes now. You do have to broadcast a second device address (0x07). If you could have a mode that advertises the keyboard as an Adjustable then it would at least allow you to have keyboard volume control under OS7. (EDIT: Found a report that says the media keys work on 6.0.7 or later)
Edited by lameboyadvance
Link to post
  • 68kMLA Supporter
Yes, ADB Busboy will work with combo devices that have both keyboard and pointing functionality.
I probably won't have the media key functionality done in the v1.0 firmware, but it is one of the first things I would add as a firmware update. The firmware can be upgraded, so one can get new features as I add them.
It won't be possible to turn power on from the keyboard. In order to do that, the keyboard has to be powered on (at least in suspend mode). Since ADB Busboy is powered by the ADB bus, it can't power the keyboard while the computer is turned off. I looked into having a battery that powers the keyboard in suspend mode while the computer is powered off, but the battery would last less than a month. The other option would be for the ADB Busboy to be powered externally instead of (or as well as) over the bus. This required too many additional components and cost. That button you see on the PCB render next to the ADB port is the power button. Instead of pressing the keyboard power button, you'll have to press the button on the ADB Busboy.
Thanks for the feedback, lameboyadvance and Huxley.
Link to post
Hi Anthon,
 Would it be realistic and viable to fit one of the PRAM battery holders onto the board? These batteries last a very long time and we should all be able to supply our own.
I know (for me), being able to turn the computer on by being able to press the power-key is one of the reasons that I love ADB. Indeed, Macally has a keyboard (iMediaKey) that allows it over USB.
Link to post
  • 68kMLA Supporter
The PRAM batteries have a smaller capacity than the ones I was considering. They only last a long time because the clock circuit uses a very very very small amount of energy. The runtime for those batteries powering a usb keyboard in standby would be less than three weeks.
Link to post
I'm definitely in for one of these when they're ready to ship. :)
Does your firmware use the USB HID spec to detect attached USB devices, and if so, which HID classes is it designed to detect? I would *love* if support existed for game controllers, and then mapped gamepad inputs to Gravis GamePad and/or Mousestick values on the Mac side. I have a Mac II and a beige Power Mac G3 hooked up to my entertainment center for gaming purposes and it would be awesome if I could use something modern like an Xbox 360 controller to play classic Mac games that have Gravis controller sets.
If this isn't on your radar, will the firmware be open-sourced in case I'd like to try my hand at adding support myself? :)
Link to post
  • 68kMLA Supporter
I had not planned on using kickstarter for this project. Managing a kickstarter campaign is a headache. Dealing with fulfilling pre-orders (such as kickstarter) is a headache, due to product changes between payment and fulfillment, from people changing addresses, etc. There's also the 5% fee on top. And people being disappointed when a project runs late, and they have already paid for it. So, my current plan is not to take orders until I have product to ship.
I might use kickstarter for another project in the future that is more capital intensive.
Link to post
It was my understanding that the ADB port provides 5V 'standby' on models that allow soft power. Would this voltage be enough to power your device/the attached input devices?
This is from Wikipedia (https://en.wikipedia.org/wiki/Apple_Desktop_Bus):
ADB's protocol required only a single pin for data, labeled ADB. Two of the other pins were used for +5 V power supply and ground. The +5 V pin guaranteed at least 500 mA, and required devices to use only 100 mA each. ADB also included the PSW pin which was attached directly to the power supply of the host computer. This was included to allow a key on the keyboard to start up the machine without needing the ADB software to interpret the signal. In more modern designs an auxiliary microcontroller is always kept running, so it is economical to use a power-up command over the standard USB channel.
The standby power comes from the power supply of the host computer (I had thought that it came from the PRAM battery) although I am open to being corrrected.
Link to post
  • 68kMLA Supporter
Currently the firmware supports keyboard and mouse HID classes. I definitely want to support game controllers. I would implement this sometime after I implement media keys. I don't currently understand how game controllers work on the ADB side. I'm guessing they need a system extension. Do games have to be designed to work with them? Or do they map controller inputs to keyboard/mouse events? Or something else?
I'm glad you mentioned some ADB gamepads, I suppose I should acquire some for testing.
As for open source, I'm not going to release the source code right away. I haven't really decided how to handle it. And since I can't change my mind after open sourcing it, I'm postponing that decision for now. I might release it under a non-commercial only license like Steve Chamberlin does with the Floppy Emu. If I am unable to dedicate time to developing it for a significant period of time, I'll definitely open source it (in the OSI, free as in freedom sense).
Edited by anthon
Link to post
  • 68kMLA Supporter
OK, I found this video about the Gravis Gamepad. http://www.killgruz.com/?p=928
Looks like the software maps buttons from the gamepad to keyboard and mouse events. What different companies made ADB game controllers? Which one had the best software? Gravis? I think I would just make the ADB Busboy convert the USB controller to a Gravis or whatever. Of course, the ADB Busboy would need to know how to map the buttons on the USB controller to buttons on the pretend ADB controller. Hmmm...
Link to post
  • 68kMLA Supporter
Also, is the software different for different types of Gravis controllers? ADB Busboy could theoretically emulate all the ADB game controllers. In that case there need to be a way to select which controller to emulate. But would it be satisfactory to choose the best controller with the best software and go with that? The only reason I can think of not to do that is if one controller has the better software but another controller has a lot more buttons.
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
