Tonebender Posted February 14, 2016 Report Share Posted February 14, 2016 First post here ... hope you don't mind me asking for some help. I was lucky to get my hands on an SE/30 for free last week, but it won't boot. The fan runs, and it starts with the familiar bing in the speaker, but the screen is dead ('cept for some glow in the tube in the back) and there is no sound whatsoever from the floppy or hdd. It has a NIC which blinks green once when I switch the power on and once more when I turn the computer off. That's it. Any suggestions as to where I should start diagnosing this thing? I've gone so far as to open the cabinet and looked around. The thing is suprisingly dusty and dirty inside, but there are no specific visual give-aways. No burn marks, no bulging caps, no obvious corrosion, etc. I'm a newbie when it comes to Macs but have plenty of experience with the soldering iron and poking around in high voltage appliances (such as tube amplifiers). Thanks for any tips! Quote Link to post Share on other sites
techknight Posted February 14, 2016 Report Share Posted February 14, 2016 This is really starting to grow a beard. Recapped? Quote Link to post Share on other sites
Elfen Posted February 15, 2016 Report Share Posted February 15, 2016 (edited) Grow a beard and its female on top of that! LOL! Tonebender - use your nose, is there a Fish Smell? A Fish Smell, no matter how slight, would indicate that the caps on the logic board has leaked. SE\30 Macs have a bad reputation of having their capacitors' seal break down and leak cap-goo everywhere, causing corrosion on a microscopic scale. This requires that the board be washed in an Ammonia & Distilled Water bath to neutralize the cap-goo acid, and then scrape it down with acetone with a tooth brush and rinse with high proof Isopropyl Alcohol before getting the board recapped. You can recap the board your self or pay somebody to do it. Forum member Uniserver has an excellent reputation of recapping Mac Logic boards, and brought mine from the brink death - literally! I recommend him. The caps are Surface Mounted so that requires something different in term of soldering that you may have done with Tube Amps. If you recap the board yourself, when you remove the cap from the logic board, brush the area with a toothbrush and acetone to remove any cap-goo that remained even after you washed it. And then wipe it down with a paper towel soaked alcohol before soldering the replacement cap. Even then, this is 50% of the job because the SE\30 is still dead and requires more work in tracking down broken traces from the cap-goo with a multi-meter and soldering a wire in its place to fix it. If you send the Logic board to be recapped and repaired, focus your attention on the Analog Board. Check for burnt components, broken solder joints and fix as necessary. Do not reheat and reflow broken solder joints! Desolder it to remove all the old solder, and resolder with fresh flux and solder. Reheating a solder joint only fixes it temporarily and you will have to fix it again in a couple of months when it breaks again. Resoldering it with fresh solder will make the repair last for years. Get the books "Dead Mac Scrolls" and "SE Upgrade and Repair Secrets," they will be helpful in future Mac SE\30 repairs. Question: Have you turned it on and adjusted the Brightness on it? There is a knob on the left bottom of the front of the machine to adjust the brightness. Many people do not realize that it is there and turn on their Mac and the screen is dark and assume that something is wrong. EDIT: The Dust and Dirt may have kept the cap-goo from spreading, so you may have lucked out in that. But still, the logic board needs recapping in the very least. Edited February 15, 2016 by Elfen Quote Link to post Share on other sites
Bunsen Posted February 15, 2016 Report Share Posted February 15, 2016 I don't know if the SE/30 is one of the machines prone to this or not, but sometimes replacing the onboard battery will allow you to boot.The quick test for that is to remove the battery (it should be on a jumper & leads) and then try to boot. If that doesn't work, leave it powered up for a half hour or so and then very quickly switch it off and on again. Quote Link to post Share on other sites
uniserver Posted February 15, 2016 Report Share Posted February 15, 2016 haven't met a se/30 mb yet that didn't massively need caps. Charles Quote Link to post Share on other sites
bibilit Posted February 15, 2016 Report Share Posted February 15, 2016 No battery required for a SE/30, check PSU outputs first, clean the board and let us informed. Quote Link to post Share on other sites
Tonebender Posted February 15, 2016 Author Report Share Posted February 15, 2016 Thanks for the quick replies, and Elfen - thanks for the thourough reply. I suppose I should start with what bibilit says: check the PSU outputs to make sure there's power there at all. I did adjust the brightness control now, and noticed there is a faint vertical line straight through the middle (although not continuous) of the otherwise black screen. Does this mean anything? Quote Link to post Share on other sites
CC_333 Posted February 15, 2016 Report Share Posted February 15, 2016 It means you probably have a cracked solder joint somewhere on the analog board. In particular, it could be the CRT deflection yoke connector (J1 on a 128k-Plus, or P1 on the SE and SE/30). If you have the nerve to operate the machine with the rear bucket off, try gently wiggling this connector (with insulated pliers) and observing the CRT for any changes (to confirm if it's the problem). You can also reference the very useful Larry Pina book, Macintosh Repair and Upgrade Secrets. An online version can be found at MacCaps.com, but I suggest also buying the print version if you can, as it's a very handy book to have around in a physical form. c Quote Link to post Share on other sites
bibilit Posted February 15, 2016 Report Share Posted February 15, 2016 (edited) from Biwa site: 2. A Bright Vertical Line in the Black MonitorSymptomsWhen starting up Mac SE/30, only a bright vertical line is shown in the black monitor. The width of the vertical line is approximately 5 mm. During start-up, you can see moving raster patterns in the vertical line. You can hear spinning sound of the hard disk drive also. The hard drive seems to be OK, and the vertical line seems to show the startup picture though very compressed to 5mm in width. DiagnosisThe horizontal sweep circuit on the analog board is broken.Ageing and/or cracks in the soldering of either (1) P1 connector, (2) C15 electrolytic capacitor (3.9uF, 35V, 85degree C, HighFrequency, NonPolar) or (3) L2 variable inductor on the analog board is the major cause of the problem.The most frequent cause is soldering failure of the P1 connector due to ageing and/or cracks. In this case, you will see the burnt and/or charred P1 connector.SolutionsThe first thing to do is to check the connector, capacitor or the inductor, and then desolder, clean and resolder them. If the problem still persists, replace the parts with new ones. 3. A Fine Vertical Line in the Black MonitorThe First Thing To Do Is To Turn Off The Power!!!!!!!!!!!SymptomsMac SE/30 shows a fine vertical line in the black monitor. In addition, you may be able to see and/or smell smoke coming up from the SE/30. It's burning. Shut off the SE/30 immediately, and pull out the power plug.DiagnosisThe horizontal sweep circuit on the analog board is broken.The R19 resistor (220 ohm, 1/4W, 5%) on the analog board is burnt out. SolutionsCheck the R19. If it is burnt, cracked and/or charred, replace it with a new one. Edited February 15, 2016 by bibilit Quote Link to post Share on other sites
uniserver Posted February 16, 2016 Report Share Posted February 16, 2016 a fried UE8 does that, from the cap ooze leaking into it. so your main board needs a recap at the very least. Quote Link to post Share on other sites
eR1c Posted March 1, 2016 Report Share Posted March 1, 2016 (edited) ..I recommend checking all the connections from the CRT to the AB, ...my SE had really bad solder joint cracks that were visible under a magnifying glass (my eyes aren't so good) ...re-soldered and that fixed a lot of my display problems. Edited March 1, 2016 by eR1c Quote Link to post Share on other sites
Tonebender Posted March 5, 2016 Author Report Share Posted March 5, 2016 (edited) I've now tested the SE/30 with a different logic board, one from an SE. The board looks fine and I'm fairly positive it works, but the SE/30 is behaving the same: black screen with the vertical line, one plong from the speaker, fan spinning, but otherwise dead. I suppose I need to do what eR1c and some others have referred to -- go through the analog board. I've also measured the voltages from the PSU/analog board, and they are a bit strange in some cases, although it isn't clear how my low-budget multimeter is showing AC voltage. Edited March 5, 2016 by Tonebender Quote Link to post Share on other sites
Tonebender Posted March 5, 2016 Author Report Share Posted March 5, 2016 Alright, so I started to resolder some of the solder joints on the back of the analog board, and now the screen is totally dead. No vertical line any more. I didn't resolder many joints, but I did the ones for the yoke connector, and R19 and a few more in the same corner of the board. I also measured the voltages on the external floppy connector on the back of the Mac (as per Classic Mac Repair Notes) and they seem okay (+12.6, +12.6, +5.02, -11.5). This is starting to bug me a bit now... Quote Link to post Share on other sites
uniserver Posted March 5, 2016 Report Share Posted March 5, 2016 (edited) the se/30 doesn't ever require joints to be resoldered on the A/B Edited March 5, 2016 by uniserver Quote Link to post Share on other sites
Tonebender Posted March 20, 2016 Author Report Share Posted March 20, 2016 Good news! This is almost embarrassing, but I tried adjusting the "cut-off" (brightness) control on the side of the analog board, and suddenly the screen as well and alive. I now see the question mark diskette symbol on boot. Darned, I really should have tried this earlier. But I did have the vertical line thing previously, so who knows what's been going on. Now I could use some more help, although I don't know exactly where to proceed. This SE/30 currently has an SE logic board in it, so I'm not totally sure how well that works (SE boards should work in an SE/30, right?). But the floppy drive is behaving erratically to say the least. It's generally sluggish mechanically speaking, and when I try sticking a system 6 boot disk in it, it spurts it out (successfully half the time) showing a floppy with an X on it... Quote Link to post Share on other sites
Tonebender Posted March 20, 2016 Author Report Share Posted March 20, 2016 Hmm, now that I think of it, maybe the SE logic board (currently mounted in the SE/30) can't handle the 1,44 MB disk drive in which I try to boot from a HD floppy ... Quote Link to post Share on other sites
Elfen Posted March 20, 2016 Report Share Posted March 20, 2016 Chances are your SE Logic Board is not a "Super Drive" Logic Board. Those have a SWIM and enhanced ROMS to handle the 1.4M Floppy Drives. The non-Super Drive boards can only handle the 800K drives because they have an IWM and older ROMS. Did you take the voltages from the hard drive power connector? The Black wire is "-"/Ground, the Red wire is +5V and the Yellow wire is +12V. The meter should be set to DC, not AC, and voltage setting to 20V (depending on the meter, it could be 50V or some other setting. I have one that has 15V as a setting... go figure). Since you got the CRT going again, did you swap to the SE\30 board to see if it works? I'm confused about that part. Quote Link to post Share on other sites
Tonebender Posted March 20, 2016 Author Report Share Posted March 20, 2016 Yes, I did check the voltages, but wasn't sure about what they should be. On the harddrive power molex connector, they are 11.9, 0, 0, and 5.4 VDC. The connector to the logic board gives -9.2, -4.9, 0, 0, 0, 0, 0 on the first row (left to right) and 11.9, 5.4, 5.4, 1.6, 1.6, 1.6, 0 on the second row. All measured when not connected. I believe they are okay until further notice. I would gladly put the SE/30 logic board back in to the SE/30, but one electrolytic capacitor is broken off (my fault), so I'm going to recap the board before I can use it again. I have the correct tantalum caps at hand, so I just need the time to do the solder work now. Quote Link to post Share on other sites
Elfen Posted March 24, 2016 Report Share Posted March 24, 2016 The connector readings are a bit scary. The 11.9 is fine for +12V. *The 5.4 is a bit high for +5V. The -4.9 is fine for the -5V. *The -9.2 is low for the -12v. The 1.6 I think is part of the video circuitry. It's the -9.2 and 5.4 are a bit off. Though the -12v (-9.2) is mostly for Serial I/O communications, it is not. The 5v (5.4) is a bit high and all the logic processes uses the 5V. At this point I think the PSU needs to be recapped. Quote Link to post Share on other sites
Tonebender Posted March 31, 2016 Author Report Share Posted March 31, 2016 Okay ...So recapping the PSU, do you mean recapping the analog board or replacing caps in the actual PSU unit? Quote Link to post Share on other sites
BadGoldEagle Posted March 31, 2016 Report Share Posted March 31, 2016 Technically, replacing caps in the actual PSU unit should do it. Quote Link to post Share on other sites
Tonebender Posted April 4, 2016 Author Report Share Posted April 4, 2016 I checked the voltages on the same locations in my working SE, and the voltages there are the same, for example -9.3 volts where you say it should be -12, and 5.4 where it should be 5.0. But I don't know, it may be sweating a bit... Quote Link to post Share on other sites
Tonebender Posted April 17, 2016 Author Report Share Posted April 17, 2016 Alright, so now I've recapped my SE/30 logic board with tantalum caps, but when I turn the computer on, all I see is this: I tried this SE/30 logic board in my SE FDHD, which gives the same results, while my SE logic board works in the SE/30 box, which indicates that the error is with the SE/30 logic board. I also tried booting the SE/30 without RAM simms mounted, and the screen is the same (while the bong is that major chord arpeggio instead). Any ideas? This is really quite tiresome... Quote Link to post Share on other sites
360alaska Posted April 17, 2016 Report Share Posted April 17, 2016 1 of 3 things usually, 1. Bad RAM or Unacceptable RAM configuration 2. Rotted UE8 Traces 3. Bad UE8 Quote Link to post Share on other sites
techknight Posted April 17, 2016 Report Share Posted April 17, 2016 Do you get sound? Chime? Slow death chime? Quote Link to post Share on other sites
Recommended Posts
Join the conversation
