gsteemso Posted February 9, 2016 Report Share Posted February 9, 2016 Seconded! This is absolutely fascinating to follow. I can mostly follow the theory, but nowhere near to the extent of ever being able to try this myself. Massively intriguing stuff! Quote Link to post Share on other sites
apm Posted April 6, 2016 Author Report Share Posted April 6, 2016 After a long break I finally got another chance to look at this. Since it's clear that some sort of phase-locking will be needed, and simple ratios of the video frequency won't always line up with the original 22.25kHz horizontal scan rate, I decided to test the effect of scan frequency on the voltages produced by the sweep circuit. I did the tests on my modified analog board which has a 100uH inductor in place of the horizontal deflection coil. I measured three points on the board where the BOMARC schematic gives typical readings: C18 which comes from pin 8 of the flyback. This voltage powers the video amplifier on the CRT board. BOMARC says it should read +32V. C19 whose signal derives from pin 7 of the flyback. This voltage ultimately goes to the brightness potentiometer. BOMARC says it should read -106V. C27 whose signal also derives from pin 7 of the flyback. This voltage powers the focus and cut-off potentiometers. BOMARC says it should read +811V. Since I don't have a HV probe, I'm taking this to be the closest proxy for the CRT anode voltage. On my modified setup, at standard 22.25kHz scan rate, I read 25.2V, -103V and 691V, respectively. So two of the three are somewhat reduced. (That said, when driven with the original resolution video, the picture is a normal size and in good focus, so it can't be that far off the original values.) Increasing the scan rate reduces the high voltage on C27, which is what one might expect: a faster scan rate means less time to accumulate energy in the yoke and flyback. Through 23.0kHz I didn't observe much change, but by 24.0kHz it fell to 670V, at 24.5kHz it fell to 655V, 25.0kHz it was 638V and by 26.0kHz it was down to 597V. There was a roughly corresponding drop in the brightness voltage. Weirdly, the voltage on C18 went *up* as the scan rate increased: from 25.2V at 22.25kHz up to 25.9V at 26.0kHz. As the frequency goes up, the picture gets bigger, indicating that the CRT anode voltage is dropping. As might be expected, dropping the scan rate had the opposite effect. At 21.0kHz, the high voltage went from 691V up to 746V; at 20.0kHz it was up to 780V; at 19.0kHz it was 794V, and at 18.0kHz it was up to 833V (about 20% higher). Again, the effect on C19 was similar, but C18 went the opposite way, dropping from 25.2V down to 24.1V. TL;DR: I think this circuit could be operated in roughly the range 19kHz to 25kHz and still have plausible voltages to work with. Above that the performance is poor; below that might damage the board. I haven't yet built a phase-locking circuit, but I tried to preview the result by driving the flyback with a signal generator tuned to exactly 2/3 of the video frequency. Here I used a Mac 13" 640x480 resolution (35.03kHz to yoke, 23.35kHz to flyback). This is the result: What this shows is a pattern of stripes every three lines. The pattern is stable if I match the frequency ratio exactly, otherwise it slowly processes up or down the screen. Here is a zoom of the edge: You can see there is a slight horizontal offset alongside a significant change in brightness. It turns out that if you follow the individual scan lines across the screen, you can see that it slowly gets dimmer over about 2 lines and then gets brighter over slightly less than 1 line. Basically, as previously discussed on this thread, I think we're seeing the CRT charging and discharging. The question is what to do about it! Phase locking will keep the pattern still, but it won't get rid of it. As long as the frequencies are mismatched, there will be some lines brighter than others. It's possible this means the whole two-frequency solution is unworkable, but I wonder if there's some other way to compensate for the brightness change and/or keep the voltage more stable without hooking up a giant HV capacitor to the CRT anode. Quote Link to post Share on other sites
Bunsen Posted April 7, 2016 Report Share Posted April 7, 2016 hooking up a giant HV capacitor to the CRT anode Is that out of the question for cost/space reasons? Quote Link to post Share on other sites
apm Posted April 7, 2016 Author Report Share Posted April 7, 2016 More like for safety reasons! The extra charge at 13kV is risky enough; finding a way to wire it up under the anode cap is doubly challenging. Looking at the screen photo again, I do wonder whether something else is going on besides just fluctuating anode voltage. It seems like an awfully steep change in brightness. With that much change over one flyback scan line, you'd expect to see a bright-to-dark gradient from left to right on the normal display, which I've never noticed at all on any compact Mac. Quote Link to post Share on other sites
olePigeon Posted April 7, 2016 Report Share Posted April 7, 2016 How difficult would it be to design a board that converts the relatively low TTL scan rate from a compact Mac to a more acceptable rate readable by normal VGA? You could then take off-the-shelf CRTs and plug them in through the converter board. Or LCDs even. Would be kind of cool to put an orange plasma LCD into a Compact. Quote Link to post Share on other sites
techknight Posted April 8, 2016 Report Share Posted April 8, 2016 (edited) Doesn't some of the electron gun voltages come from the flyback secondaries? I wonder if there is a spot-killer or a G1/G2 voltage thats flyback-derived with poor or no filtering causing the interference. It has to be something along these lines, because you can run CRTs with flybacks that are completely different frequency patterns than the yoke. And be fine. How do I know this? Well Phillips did this in their late CRT projection sets before going away completely. They used HVG blocks instead of flybacks. it was a self-contained, self-oscillated flyback that ran on its own, separate from the yoke. I know this, because I had to change a few in my day. Oh, and the Motorola golden view VT-71 tube type antique TV sets did the very same thing. They were electrostatic CRTs, but that didnt matter. the high voltage was generated using a self oscillated design and tickler coil on the high voltage rectifier tube. So it CAN be done. Edited April 8, 2016 by techknight Quote Link to post Share on other sites
apm Posted April 9, 2016 Author Report Share Posted April 9, 2016 Doesn't some of the electron gun voltages come from the flyback secondaries? I wonder if there is a spot-killer or a G1/G2 voltage thats flyback-derived with poor or no filtering causing the interference. True, almost all of the voltages except the video and the filament heaters come from the flyback secondaries. Two of them have some pretty significant capacitors (big electrolytics plus .01uF ceramics) but the voltages for focus and cut-off only get .01uF capacitors. I didn't notice a big variation in those voltages on the scope but I'll have to look more closely. I wonder how much variation would be needed to see such an effect on screen, and which voltages would be the most sensitive? Two other ideas: first, perhaps there's some interference on ground causing a relative voltage change, most likely directly in the video signal which is only about 1V when it arrives at the CRT board. Second, if it is from high-voltage, perhaps it's the bleeder resistor in the flyback discharging the CRT too quickly? I guess this seems unlikely as I thought it was supposed to act over a period of several seconds to minutes, not microseconds. Did the separate flybacks in those projection TVs have bleeder resistors on them? Quote Link to post Share on other sites
CC_333 Posted April 9, 2016 Report Share Posted April 9, 2016 I kinda thought (but wasn't 100% certain) that many, if not most, modern flybacks (those from the late 80's, 90's and 2000's) had bleeder resistors for safety. Is this true? This is a spectacular project, by the way! c Quote Link to post Share on other sites
techknight Posted April 10, 2016 Report Share Posted April 10, 2016 Did the separate flybacks in those projection TVs have bleeder resistors on them? Projection flybacks did have bleeder resistors in them, But they also had an HV splitter block that sat between the CRTs and the flyback, and it also had a feedback wire for regulation purposes I believe. Quote Link to post Share on other sites
apm Posted August 28, 2017 Author Report Share Posted August 28, 2017 After a long hiatus, I'm going back to this resolution-changing project armed with a new approach. I've established (as techknight and others have found) that the flyback transformer on most of the compact Macs can't be run at VGA or higher resolutions -- no matter what external capacitor is used, it just won't "fly back" fast enough at the end of each scan line. Approach #1, described earlier in this thread, was to use two different analog board circuits, one for the flyback and one for the yoke. That sort-of worked. Now approach #2 is to retry the whole thing using the Classic II analog board (also found on late-model Classics). This board uses a totally different horizontal circuit with a totally different flyback transformer: In this thread, I posted a little more about what I discovered about this transformer. Meritron appears to make a lot of transformers to this form factor, all of which have similar part numbers, but are not in fact the same part inside. So it's an open question of whether this transformer will work at higher frequencies. However, first indications are encouraging: The image above shows the voltage pulse on the collector of the HOT (QL2, an IRF740 MOSFET). This transistor is hooked up to the primary of the flyback transformer and to the capacitor CL6 which should set the speed of the flyback pulse. Here we see a pulse of 316V which lasts for 8us. Compared to the earlier model compacts, the pulse is much cleaner -- a clear half-sine instead of the ringy mess you find on the older circuit. To get this board operating at VGA resolution, that pulse needs to last closer to 5us. But for the same screen width, there will be a similar amount of area under the curve, which means shortening the pulse also raises the voltage. So the next steps will be (1) to replace the IRF740, which is rated at 400V, with a part that can withstand higher voltage, and (2) to replace CL6 with a smaller capacitor to see if the pulse can be sped up. From there I'll see how it runs at higher frequencies. More details soon, hopefully. Quote Link to post Share on other sites
techknight Posted August 28, 2017 Report Share Posted August 28, 2017 (edited) I am surprised they are using a MOSFET in the horizontal output section, I almost never see that. It would be better to go traditional and use a standard bipolar NPN transistor with built in damper diode. I guess the good thing about a mosfet, you dont need a drive transformer. you could get away with a good old classic 4426/4427. (thats what I used to use in my old class D designs back in the day.) Edited August 28, 2017 by techknight Quote Link to post Share on other sites
apm Posted August 29, 2017 Author Report Share Posted August 29, 2017 (edited) Yes I'm sure it must be because using a MOSFET saves the cost and complexity of the base drive circuit. Even the early Classic analog board uses a MOSFET for the HOT (IRF640 in that case), while the earlier compacts use a BJT (BU406) with a transformer. Since the Classic was designed for low cost above all else, I have to assume that the economics of transformers vs. active devices shifted between 1983 and 1990. It does seem to be hard to find MOSFETs rated much above 650V drain-source voltage. It looks like on a lot of horizontal circuits, including the early compacts, the HOT drives a different tap than the flyback capacitor is connected to. I assume that means the voltage at the HOT is only a fraction of the voltage that appears at the capacitor. For example, in a 9" VGA monitor I disassembled, the HOT is only rated at 200V, but the capacitor is rated up to 630V. They're connected to different taps. Unfortunately, the flyback transformer in the late-model Classic doesn't appear to have extra taps, so the HOT will just have to deal with whatever pulse appears on the capacitor. I'll stick with MOSFETs for now, unless you can suggest a good generic base drive transformer? Edited August 29, 2017 by apm Quote Link to post Share on other sites
K55 Posted August 30, 2017 Report Share Posted August 30, 2017 I've had good luck with the IP series of mosfets from infenon, you can get a 800V 5A transistor for a little under a dollar these days. I mean you'll probably need a huge ass heat-sink but eh, the gate capacitances and Rds resistances are much, much lower than the late 90s Quote Link to post Share on other sites
Trash80toHP_Mini Posted August 30, 2017 Report Share Posted August 30, 2017 AM caffeine deprivation mode insanity for the day: been poking around in my old SuperMac Spectrum24 project and had a thought: There's a slight chance we could crack this problem from the opposite direction, at least for grayscale at standard resolution. The software for this very early NuBus card calculates the oscillation required by its hardware to run any resolution at any refresh rate within the limits of its 3MB of VRAM, presumably for compatible crystal specs.. WAG: working backwards from the SE/30 CRT input spec, working out a video card's output timing spec ought to be easy enough. Insane part: Development of a video card for the SE/30 68030 "PDS" wedged into the system at the CPU socket level. _ by removing the Video ROM of the SE/30, the video subsystem is deactivated and its interrupt for PseudoSlot $E is freed for use. _______ IIRC tk mentioned possible complications elsewhere in the remains of the video subsystem . . . whatever. _ direct access to the interrupt for $E at the CPU socket negates the problem of it not being present on the 030 PDS slot. _ using $E for a video card preserves use of the interrupts available on that slot for max conventional expansion capability. Coffee is kicking in so I've lost fuzzyfocus on this notion while digging up relevant lines of research: _ design reference for Grayscale neck board development is well documented _ the Toby hack was inspired by discovery of a reference design for discrete, off the shelf component implementation of a video card _______ aside from DeclROM, only two ©Apple ICs are present, they look to be NuBus MUX components and if so, irrelevant _ the SE/30 socket version of the PowerCache offers reference design for 030 socket buffering requirements. _ all aspects(?) of Video Driver development is conveniently documented in DCaDftMF Now that I'm waking up, I'm wondering if this is relevant to your Retina project, but I'm hitting the button anyway. Quote Link to post Share on other sites
apm Posted August 30, 2017 Author Report Share Posted August 30, 2017 I've had good luck with the IP series of mosfets from infenon, you can get a 800V 5A transistor for a little under a dollar these days. I mean you'll probably need a huge ass heat-sink but eh, the gate capacitances and Rds resistances are much, much lower than the late 90s You're completely right. Looks like I was incorrectly filtering for MOSFETs with < 100mOhm on resistance, when I meant to be looking for < 1 ohm. For example, the Infineon IPP80R280P7 has better specs than the IRF740 in essentially every way: voltage rating, on resistance, gate charge. I guess it shouldn't be surprising that the core technology of switching power converters has improved just a bit in 20 years! Quote Link to post Share on other sites
techknight Posted August 31, 2017 Report Share Posted August 31, 2017 they also explode alot easier and more often than the 90s. I honestly think they over-rate these transistors IMHO, especially in Class D circuitry. Quote Link to post Share on other sites
apm Posted September 19, 2017 Author Report Share Posted September 19, 2017 Well I've changed the IRF740 for an IPP80R280P7 (800V rating), and the Mac still works. No change in picture or in signal at the gate. Next up, messing with the flyback capacitor and seeing what happens to the retrace time and the secondary voltages. Quote Link to post Share on other sites
apm Posted September 22, 2017 Author Report Share Posted September 22, 2017 More progress: on the late Classic analog board, changing capacitor CL6 does indeed change the retrace time in the way I would expect. Here it was with the original .028uF capacitor: And here it is after replacing CL6 with .018uF: Theory suggests that reducing CL6 by a factor of N would reduce the retrace time by a factor sqrt(N) while increasing the peak retrace voltage by sqrt(N). What we see here pretty much matches that on both time and voltage. I tried CL6 = .022uF as well and also got results that match the theory. I also find that the secondary flyback voltages as measured on CL2 and CL5 increase by the same ratios -- i.e. smaller CL6 = higher flyback secondary voltages. That has the side effect of making the picture smaller (because the anode voltage is higher); the other voltages to the CRT can be readjusted by the pots on the analog board. However I'm not sure at what point a higher anode voltage goes out of spec for the CRT. Anyway, here's what this all means for resolution changing: The retrace time on the analog board as it stands is 8.0us. According to the VGA spec, it can be no more than 5.7us (sync pulse plus back porch). That's a reduction of sqrt(2) meaning we need to cut the value of CL6 in half: .014uF. That's not a standard value, so we could choose .012uF instead. On that basis, I'd expect a flyback pulse of 473V. The newly replaced HOT can handle that, but it turns out diode DL5 (BYV26B, rated at 400V) also needs to be replaced with a higher-voltage part. The secondary voltages would be -186V and 1130V; I believe those are still within the rated limits on the relevant parts. But it would be better if the flyback secondary voltages didn't have to keep increasing. So I may try to find some way to avoid having all the energy of the retrace making its way through the flyback; maybe adding another inductor somewhere around the primary? I still need to think about how that might work. Quote Link to post Share on other sites
techknight Posted September 23, 2017 Report Share Posted September 23, 2017 (edited) You dont want to run a 9 Inch CRT past 13.5KV if you can help it. Any more, you will get arcing, or worse, X-ray production! If the secondaries are increasing, Why not drop the incoming B+? You have to adjust the B+ all the time for different frequencies. For temporary sake, Isolate the sweep B+ away from the main power supply and use a bench unit. Edited September 23, 2017 by techknight Quote Link to post Share on other sites
apm Posted September 23, 2017 Author Report Share Posted September 23, 2017 (edited) Using a bench unit for B+ was my plan once I start changing frequencies. The problem is that B+ controls both the secondary voltages and the screen width. On the late Classic board there's no adjustable inductor at all, only a changeable B+ for controlling width. Higher resolutions will actually need even more B+ to reach the same width at higher frequency. Looking at it another way, once you get to the end of a scan line there's a certain amount of energy stored up in the flyback and yoke, which is directly related to the screen width. If you want to discharge it faster, the voltage has to go higher. How do multisync monitors get around this problem? Edited September 23, 2017 by apm Quote Link to post Share on other sites
techknight Posted September 24, 2017 Report Share Posted September 24, 2017 (edited) I know with multisync monitors, they have relays that cut certain circuits in and out, but more importantly, it has a sync microprocessor. it shapes the drive pulses digitally, and stores the width, height, keystone, pincushion, etc for each and every supported frequency. Also the B+ is variable digitally in those units as well. Also sony multisync monitors, they split the flyback and yoke circuits completely. there are 2 HOTs. The conclusion here is the flyback is probably fixed-frequency which is phase locked to the yoke frequencies. the last of the CRT projection sets were HD, and a grand majority of those were 2 separate circuits as well. Then the cheaper ones had a single output, but the deflection circuit was designed to be fixed-frequency and it used digital up/down scaling like LCD sets today. Edited September 24, 2017 by techknight Quote Link to post Share on other sites
apm Posted October 31, 2017 Author Report Share Posted October 31, 2017 So, some voltage measurements on changing the sweep frequency. We start with CL6 = 0.018uF (smaller than the factory 0.028uF), and with the HOT and the flyback diode both replaced with parts tolerant of 800V spikes. I measured three flyback secondary voltages: across CL1, CL2 and CL5. CL1 was unchanged at 14.8V regardless of frequency. "Flyback pulse" is the peak voltage of the flyback primary pulse across CL6 during retrace. Frequency Flyback pulse CL2 CL5 22.25kHz 398V -155V 958V 23.0kHz 382V -150V 925V 24.0kHz 366V -143V 881V 25.0kHz 354V -137V 843V 26.0kHz 338V -131V 806V 27.0kHz 326V -125V 773V 28.0kHz 314V -120V 741V 29.0kHz 302V -115V 711V 30.0kHz 289V -110V 683V 31.0kHz 281V -106V 656V 32.0kHz 271V -102V 631V 33.0kHz 261V -98V 609V 34.0kHz 253V -94V 585V 35.0kHz 245V -91V 566V 36.0kHz 237V -88V 544V For reference, the nominal values with the original parts and original frequency were 310V, -122V, 740V. That's pretty much equivalent to what I get a 28.0kHz with the smaller CL6. So the conclusion seems to reasonably be that a smaller CL6 and a higher frequency work happily together. Based on the above calculations, I expect CL6 = 0.014uF would be right for VGA, and 0.011uF for the Apple 13" resolution (35kHz scan rate). As I increase the frequency, the picture gets both narrower, taller and dimmer. That's what I would expect. Faster scan = less time to sweep left-to-right, which shrinks the picture horizontally. But it also means lower high-voltage, which reduces brightness and makes the vertical deflection more effective. So far, all signs point to higher resolutions working just fine on this analog board. The next step is to try an actual VGA signal, and then if the picture can't be made wide enough, figure out how to boost the B+ voltage. Quote Link to post Share on other sites
apm Posted December 27, 2020 Author Report Share Posted December 27, 2020 Finally, over 5 years after I started this thread, here we are: VGA 640x480 in grayscale on a Classic CRT! The above image is displayed with an original CRT and an original (modified) analog board, with a replica Xceed CRT neck board for grayscale. The display is coming from an LC II but could be any VGA source. A synopsis for those just joining this thread: the goal is to increase the resolution of the compact Mac screen from 512x342 to 640x480 (or higher). There have been several nice hacks of the display before, but they usually involve replacing the CRT or at least putting in the guts of another monitor like a 12" Apple Monochrome Display. Here, I'm trying to increase the resolution using the existing CRT, existing analog board and existing flyback. It turns out, for reasons explained earlier in the thread, that it's much easier to modify the late-model Classic analog board (used in the Classic II and later builds of the Classic) than any of the earlier compacts, because the late Classic board uses a different and more flexible flyback transformer. The challenge in a nutshell is that increasing the screen resolution means increasing the horizontal scan frequency from 22.25kHz in the original to 31.5kHz (VGA) or higher. The horizontal sync is used to drive the flyback which generates all the voltages to the CRT, and the circuits in the compact Macs are very much not multisync: they are finely tuned to operate at exactly 22.25kHz and VGA is a long way from that. The specific barrier to higher horizontal scan rates is the retrace time -- how long it takes the beam to go from right to left of the screen. This is ~8us on most compacts, but for VGA it needs to be 5us or less, or you'll end up with foldover on the left part of the screen. Shortening the retrace time inherently means increasing the retrace voltage pulse (see earlier plots in this thread). That pulse is what powers the flyback and generates all the CRT voltages. Increase the pulse and all the other voltages go up with it, which is bad. Hence the problem changing resolution. Anyway, I found a working solution. It needs the following large components: 1. Classic or Classic II with late-model analog board (logic board is not used) 2. Micron Xceed replica grayscale CRT neck board - I used a PCB from @Bolle. 3. Benchtop power supply capable of generating 45V at 0.3A. Highly recommended that this is adjustable so you can ramp it up slowly for testing. 4. VGA signal source - I used an LC II, but it could be anything These are the modifications to the analog board (referring to BOMARC schematic): 1. Replace capacitor CL6 (originally 0.028uF) with 8.2nF, rated at 600V or higher 2. Replace MOSFET QL2 (originally IRF740) with IPP80R280P7 or similar (rated at 800V) 3. Remove voltage regular IP2 (LM317) and diode DP13. The 45V benchtop supply should patch into the output of IP2 (pin 2). It may also be beneficial to replace CP11 (220uF/50V) with a part with a higher voltage rating, though I haven't done this. 4. (This is the part that took me the longest to figure out) Cut the trace going to pin 4 of the flyback transformer (which connects it to the now-45V supply). Wind 16 turns of wire around the core of the flyback (see photo) and solder across the trace you just cut. Starting from the side of the trace connected to the power supply, the windings should go counterclockwise around the core, finally connecting to pin 4 of the flyback. More on this below. 5. HSYNC and VSYNC need to be supplied by the external VGA signal. At least for HSYNC the sync pulse needs to be lengthened to >10us for the analog board to be happy with it. This can be done with a 74LS123 one-shot multivibrator (I also use a similar circuit for VSYNC). These connect to pin 5 (violet wire) and pin 4 (grey wire) of the cable that goes to the logic board. 6. The CRT neck board is soldered to the analog board in the Classic. It needs to be desoldered to attach the Xceed neck board. I found it helpful to desolder the wires at the neck board side and attach a 12-pin Molex connector like on the SE/30 analog board, so that I could use the existing cable harness I had for the Xceed. The VGA video signal bypasses the analog board entirely and goes straight from the HD15 connector into pin 6 on the Xceed board. 7. Without the logic board, there's no brightness control. I replaced it with a signal generator but a constant 5V source should work fine. It goes to pin 9 (blue wire) of the cable assembly that goes toward the logic board. Once all of that is done, it can be tested and adjusted. For testing, I usually bring up the video signal and 5V to the 74LS123, then I power on the Classic, then finally I gradually bring up the 45V supply voltage to the flyback. It's important the sync signal stays stable while the circuit is powered. I blew up a couple MOSFETs when I turned off the 5V supply and the MOSFET stayed on too long, resulting in an enormous voltage spike when it finally turned off. To get the picture mostly centred, turn PL3 (H. Center) control to its minimum value. Even at a standard resolution, the Xceed board needs some adjustment. With the brightness all the way up, I adjusted PL2 (Cut-Off) on the analog board and the trim on the CRT neck board until I was happy with the brightness and linearity of the grayscale. Then I adjusted the focus (PL1). Why it works: Reducing CL6 from 28nF to 8.2nF reduces the retrace time to 5.0us. This is short enough to fit between scan lines at VGA, where there is 6.3us from the end of the visible part of one line to the start of the next. Because the horizontal frequency is higher, the beam needs to move faster across the screen. That means we need a higher drive voltage than before. In the original Classic the flyback is driven from 30V, but I found 45V produced the right width of picture. The result of the above will be a much higher retrace pulse: 486V instead of 310V. That would blow up the original QL2, which is why we substitute the higher-spec part. Now the big problem is that all the flyback secondary voltages are directly proportional to the retrace pulse. We really don't want everything to be 50% higher! I stumbled around on this for a while, before I realised that we could change the turns ratio of the transformer just by winding some extra turns around the core. Basically, we want more turns on the primary side. I arrived at 16 turns by trial and error. I haven't tested this on other machines, and I don't know if it is sensitive to how tightly the turns are wound or what gauge of wire is used. Based on my measurements I expect 16 is a minimum number of turns rather than a maximum. The 74LS123 is needed because the Classic HSYNC circuitry filters out signals that don't stay low for at least ~10us. Without it you'll get no retrace pulse at all. Also we need QL2 to stay turned off for the entirety of the retrace time, which is actually a bit longer than the VGA sync pulse. With all of these modifications in place, I measured the following voltages: Pulse at CL6: 486V / 5.0us [original: 310V / 8.0us] CL1: 13.0V [original: 14.7V on my set; BOMARC says 12.6V] CL2: -131V [original: -123V on my set; BOMARC says -109V] CL5: 786V [original: 740V on my set] HV: estimated at about 14kV [BOMARC says 13kV] The video signal is fairly clean though it looks like there's a possibility of slight ghosting because of an impedance mismatch between VGA and the Xceed board. That needs further investigation, but the good news is that the levels match out of the box. My modification drives the Xceed video amplifier with a 45V supply rather than 30V, but I haven't seen any adverse effects of this. Next I need to tidy this up a bit and try to reduce the dependence on external supplies (e.g. find a boost converter for the 45V). I'd like to get this into an SE/30, but its flyback transformer is much less flexible. So one possibility is to design a hybrid board where the horizontal circuits of a Classic could be transplanted into an SE/30 form factor. Quote Link to post Share on other sites
ymk Posted December 29, 2020 Report Share Posted December 29, 2020 Great work! Quote Link to post Share on other sites
just.in.time Posted December 29, 2020 Report Share Posted December 29, 2020 This is awesome, well done! Quote Link to post Share on other sites
Recommended Posts
Join the conversation
