Jump to content
Peripherals: LINKS Project: Rev. 3.0
  • Please log in to reply
35 replies to this topic
#21 beachycove
beachycove
  • 68020
  • LocationOntario
Posted 04 January 2012 - 08:23 PM
Explanation of TrueType, Postscript and Bitmapped fonts, including what is or can be used in combination with what (e.g., bitmapped and TrueType in the same font folder).
#22 beachycove
beachycove
  • 68020
  • LocationOntario
Posted 04 January 2012 - 08:28 PM
Extracting a font from software for system-wide use using RedEdit. Technique successfully adapted/ used to extract Espy Sans from System 7.5 Apple Guide.
#23 Bunsen
Bunsen
    Admin-Witchfinder-General
  • Administrators
  • LocationMelbourne, Australia
Posted 07 January 2012 - 08:32 PM
Power supply pinouts:
http://www.computerc...docs/mchk.shtml
http://www.xlr8yourm... ... inouts.jpg
(Thanks, sunder and zuiko21)
RAM:
Macintosh RAM Configurations for Power Macintosh Computers. We DO NOT GUARANTEE
these listings are complete or accurate. Check other Web sources including Apple
"Applecare Knowledge Base archives" for complete information. Corrections would
be appreciated.
Macs prior to the PowerMac use either 30-pin SIMMS or 72-pin SIMMS (2K refresh), with
one exception: the Mac IIfx uses 64-pin SIMMS. The Mac 128K and 512K do
not accept additional memory. Multiple entries for a model means it may
accept various kinds of memory. Definitions of these terms are available via a Web
search.
Power Mac 4400, 7220 168-pin DIMM 3.3 V unbuffered EDO
Power Mac 5200/75 LC, 5260/100 72-pin SIMM 2K refresh
Performa 5200, 5210, 5215, 5220 72-pin SIMM 2K refresh
Performa 5260, 5300, 5300/100LC 72-pin SIMM 2K refresh
Power Mac 5400 Performa 6400, 6360 168-pin buffered EDO or FPM DIMM 5V
Power Mac 5400 Performa 6400 168-pin buffered EDO DIMM 5V
Power Mac 5500, 6500 168-pin DIMM 5V EDO
Performa 6200, 6205, 6214, 6216, 6218, 6220, 6230, 6290, 6300, 6480 72-pin SIMM 2K refresh
Power Mac 6100, Performa 6110, 6112, 6115, 6116, 6117, 6118 72-pin SIMM 4K refresh
Power Mac 7100 72-pin SIMM 4K refresh
Power Mac 7200 168-pin 5V DIMM **
Power Mac 7500 Series 168-pin 5V DIMM
Power Mac 7300, 7600 Series 168-pin 5V DIMM
Power Mac 8100 72-pin SIMM2 4K refresh
Power Mac 8500, 8600 Series 168-pin 5V DIMM
Power Mac 9500, 9600 Series 168-pin 5V DIMM
G3, G4 Macs: not listed here yet.
The Power Mac 7300, 7500, 7600, 8500, 8600, 9500, and 9600
series computers have a memory interleaving feature. Install identical pairs
of DIMMS in same-numbered slots to improve performance.
**Note: for PowerMac 7200's, EDO DIMM memory MAY DAMAGE THE MOTHERBOARD! according
to Apple. For the other DIMM models EDO memory will function but not as EDO memory. Check
Apple's document "Power Macintosh: Using FPM, EDO, SDRAM, and SGRAM", Apple
Article ID: 19456, for details.
The PowerMac 6100 will accept 64MB* 72 pin SIMMS. Other Macs which accept
72 pin SIMMS will only see 16MB of a 64MB SIMM.
This document last updated: Aug 1 2002
* Various sources have reported success with 128MB SIMMs: search for further information before purchasing.
(Thanks, Herb's Mac stuff)
have you searched? Seeks: Nubus PDS DSP PB170 Newton; TRS-80 III/4; CBM BBC SX-64 CX5M Likes: 8bit luggable palmtop terminal NC tablet audio MIDI analog FM drum synth steam&dieselpunk; 1930-1980 lab/comm/mil Score! NC100 PB190 Q950 IIe-PDS
#24 theos911
theos911
  • 6502
  • LocationCleveland, Ohio
Posted 17 January 2012 - 11:38 PM
Sillydog's Netscape Navigator Archive~
Version 4.x specifically http://sillydog.org/narchive/full4.php ,but the site contains links for every version and platform + neat trivia and release dates / standards support info.
68k: Duo 230, 270c, 280c, DuoDock II, DuoDock Plus, Apple Minidock, Newertech Netdock & Ultradock 16sce, 540c, 190
PPC: 2300c, 5300ce, Performa 6500, Wallstreet II 300, B&W Powermac G3 500, iMac G3 700
PRAM? When in doubt, Pull it out!
#25 Bunsen
Bunsen
  • Administrators
Posted 19 January 2012 - 08:32 AM
Powerbook Batteries: pre-G3
[attachment=0]017f15c2.png[/attachment]
Thanks Mk.558
#26 Trash80toHP_Mini
Trash80toHP_Mini
    NIGHT STALKER
  • 68040
  • LocationBermuda Triangle, NC, USA
Posted 21 February 2012 - 06:44 AM
It may be almost four years old, but I really enjoyed this article by Charles Moore:
Low End Mac's Compleat Guide to the Pismo PowerBook.
#27 Bunsen
Bunsen
  • Administrators
Posted 17 May 2012 - 07:46 AM
http://www.jcsenterp... ... ssors.html
An excellent page on compatibility of G4 CPU modules between different models.
From theos911's post here.
Also:
Subject: G4 processor swaps
You can use Sawtooth/Gigabit Ethernet CPUs in a Digital Audio without any changes at all. Apple System Profiler may say it is running slow but other programs can generally detect it properly. (I have personally tested this, including changing the resistors and running benches) The only issue is that you are running a really slow CPU and the bus gets dropped down to 100MHz but it is good for testing a suspect motherboard or CPU.
I have not tried in a QS, but the QS is similar enough to the DA that it *should* probably work. ymmv
#28 Bunsen
Bunsen
  • Administrators
Posted 06 June 2012 - 03:16 PM
Daystar PowerCache and 030 (SE/30/IIsi) PDS adapter
Subject: SE/30 Powercache adapter?
Finally got some high resolution photos here:
Posted Image
Posted Image
Posted Image
Posted Image
Unresized scans:
http://farm8.staticf...efd540116_k.jpg - underside
http://farm8.staticf...e5525e0ed_k.jpg - topside
Best I can do with the scanner I have on hand. Friend of mine has a really nice, really expensive DSLR that I'm sure would do a better job. This sucker is for sale if anyone is interested; still untested but I'd accept a return+refund if it didn't work.
#29 Bunsen
Bunsen
  • Administrators
Posted 30 November 2012 - 09:19 AM
MinerAl's logic board interchange chart.
Which Mac logic boards share the same form factor and can be fitted in the same cases.
#30 Trash80toHP_Mini
Trash80toHP_Mini
    NIGHT STALKER
  • 68040
Posted 10 May 2013 - 03:08 PM
Need link to the old Ports & Pinouts(?) document that shows the @$$end of Macs up to the day the document was created.
edit: I found it on the QS'02, the filename is mac_ports_pinouts.pdf for my copy, coul
Didn't find a link, so I may have changed the name. It's a VERY useful Apple Document.
Ports and Pinouts ServiceSource Document
#31 Bunsen
Bunsen
  • Administrators
Posted 11 May 2013 - 04:13 PM
This seems like as good a place to leave this as any, at least till we have a functioning wiki again.
The "Family tree" of development and technical documentation for early macs:
Subject: Another IIci ROM hack
Here's the RoadMap:
Posted Image
. . . with a couple of other Titles I'd like to nab!
Here's the .TXT info:
Posted Image
#32 Bunsen
Bunsen
  • Administrators
Posted 08 September 2013 - 09:07 AM
High res versions of above:
Posted Image
Posted Image
Posted Image
#33 volvo242gt
volvo242gt
  • 68000
  • LocationDuvall, Washington, USA
Posted 03 March 2014 - 12:40 AM
Re: Slot Info - I've found a working download link. Not sure if it's ok to post it on the site, but it's available on macgui.net...
-J
Mac: Plus 4/250, SE 4/230, IIsi 17/250, IIci 4/500, IIfx 32/1G, C650 48/1.2G/CD, G4/1.2GHz DA 1.5G/80G/30G/DVD-RW, C2D 2.16 iMac 2G/250G, Macbook 13" 2.4 C2D 3G/160G/DVD-RW
Pre-Mac: ///, //e x2, IIgs
Other: iPhone 4s 32GB, Dell D830
#34 Trash80toHP_Mini
Trash80toHP_Mini
    NIGHT STALKER
  • 68040
Posted 03 March 2014 - 04:42 AM
The last I checked it had been released for non-business uses, the entire Gauge Series, IIRC. TattleTech was the same story as I recall. Download it and read the UA, if my memory isn't leaking like the proverbial sieve, it should be OK to post a link. Maybe PM Cory first?
Sharing actual, working links is what the thread's all about. Just don't post linkage to known pirate's coves. ;)
#35 volvo242gt
volvo242gt
  • 68000
Posted 03 March 2014 - 06:13 AM
True dat. Hence the reason why I was leery of posting the link in the first place. I d/l'ed the BNHQ file and unencoded it. Read Me file doesn't say anything about the User Agreement. Will have to fire up the IIfx or the G4 and ftp into the MacBook to transfer the files over to one of those machines, then check to see if there's anything in the UA.
-J
#36 Trash80toHP_Mini
Trash80toHP_Mini
    NIGHT STALKER
  • 68040
Posted 10 May 2017 - 03:15 PM
Found the list of searchable Service Source filenames. (Service Manuals)
12_monochrome_display.pdf
12_rgb_display.pdf
16_color_displaac
21_color_display.pdf
adb_devices.pdf
airport.pdf
applecd_150.300.pdf
applecd_300e_plus.600e.pdf
applecd_sc.sc_plus.pdf
applecolor_highres_rgb_mon.pdf
appledesign_powered_speakers.pdf
applevision_1710av_display.pdf
apple_3.5_drive.pdf
apple_400k_drive.pdf
apple_800k_drive.pdf
apple_color_printer.pdf
apple_pc_5.25_drive.pdf
apple_scanner_products.pdf
apple_studio_display.pdf
apple_superdrive.hdi_20.pdf
apple_tape_backup_40sc.pdf
apple_tv.fm_radio_system.pdf
audiovision_14_display.pdf
basic_color_monitor.pdf
classic_ii.performa_200.pdf
colorsync_17_displays.pdf
colorsync_20_displays.pdf
color_classic.pdf
color_classic_ii.perf_275.pdf
color_laserwriter_12.600_ps.pdf
color_onescanner.pdf
color_onescanner.b.pdf
color_onescanner_1200.30.pdf
color_onescanner_600.27.pdf
color_plus_14_display.pdf
color_stylewriter_1500.pdf
color_stylewriter_2200.pdf
color_stylewriter_2400.pdf
color_stylewriter_2500.pdf
color_stylewriter_4500.4100.pdf
color_stylewriter_6500.pdf
color_stylewriter_pro.pdf
communications_cards.pdf
dvd.pdf
emate.pdf
envelope_feeder.pdf
ethernet_and_localtalk_products.pdf
external_hard_drive_sc.pdf
g4cube.pdf hard_disk_20.pdf
hard_drives.pdf
hdi20_1.4_drive.pdf
highres_monochrome_monitor.pdf
ibk01.pdf
ibk14.pdf
ibk_dusb.pdf
ibook.pdf
imac.pdf
imac_early2001.pdf
imac_sl.pdf
imac_summer01.pdf
imac_slot_loading.pdf
imacdv.pdf
imac.flatpanel.pdf
imagewriter_ii.pdf
imagewriter_ii.l.pdf
imagewriter_lq.pdf
laserwriter_10.600_a3plus.pdf
laserwriter_12.640_ps.pdf
laserwriter_16.600_ps.pdf
laserwriter_8500.pdf
laserwriter_ii.pdf
laserwriter_plus.pdf
laserwriter_pro_600.630.pdf
laserwriter_pro_810.pdf
laserwriter_select.pdf
lc_520.550.575.pdf
lc_580.performa_580cd.pdf
macintosh_128k.512k.pdf
macintosh_color_display.pdf
macintosh_ii.iix.iifx.pdf
macintosh_iisi.pdf
macintosh_iivx.vi.perf_600.pdf
macintosh_plus.pdf
macintosh_portable.pdf
macintosh_processor_upgrade.pdf
macintosh_se.pdf
macintosh_se.30.pdf
macintosh_tv.pdf
messagepad_100.110.120.130.pdf
messagepad_2000.2100.pdf
modems.pdf
multiple_scan_14_display.pdf
multiple_scan_15av_display.pdf
multiple_scan_15_display.pdf
multiple_scan_1705_display.pdf
multiple_scan_17_display.pdf
multiple_scan_20_display.pdf
multiple_scan_720_display.pdf
network_server_500.700.pdf
pb_g3_series_bronze.pdf
pc_compatibility_card.pdf
performa_400_series.pdf
performa_500_series.pdf
performa_6100.pdf
performa_6200.6300.pdf
performa_630_series.pdf
performa_display.plus.pdf
plw_300.320_lw_4.600_ps.pdf
plw_sc.nt.ntr.ls.pdf
pm7300.7500.7600.ws7350.pdf
pm8600.9600.ws9650.pdf
portable_stylewriter.pdf
portrait_display.pdf
powerbook_100.pdf
powerbook_140.145.b.170.pdf
powerbook_1400_series.pdf
powerbook_150.pdf
powerbook_160.165.180.pdf
powerbook_165c.180c.pdf
powerbook_190.5300.pdf
powerbook_190.5300_rea.pdf
powerbook_200_series.pdf
powerbook_2300_series.pdf
powerbook_2400c.pdf
powerbook_3400c.g3.pdf
powerbook_500_series.pdf
powerbook_550c.pdf
powerbook_duo_dock.pdf
powerbook_duo_minidock.pdf
powerbook_fw.pdf
powerbook_g3_series.pdf
pbg4.pdf powermac.perf_5200.5300.pdf
powermac.perf_5260.5280.pdf
powermac.perf_5400.5500.pdf
powermac.perf_6400.6500.pdf
powermac_4400.pdf
powermac_6100_series.pdf
powermac_7100_series.pdf
powermac_7200_series.pdf
powercd.pdf
powermac_4400.pdf
powermac_8100.ws_8150.pdf
powermac_8500_series.pdf
powermac_9500_series.pdf
powermac_g3_all_in_one.pdf
powermac_g3_blue.white.pdf
powermac_g3_desktop.pdf
powermac_g4.pdf
powermac_server_g3_minitow.pdf
powermac_upgrade_card.pdf
quadra.centris_610.ws_60.pdf
quadra.centris_650.pdf
quadra.centris_660av.pdf
quadra.lc_630.performa_640.pdf
quadra_605.lc_series.pdf
quadra_700.mac_iicx.iici.pdf
quadra_800.ws_80.pdf
quadra_840av.pdf
quadra_900.950.ws_95.pdf
quicktake_100.pdf
quicktake_150.pdf
quicktake_200.pdf
setup.pdf
sheet_feeder.pdf
sound_cards.pdf
studio.pdf
studio.15dvi.pdf
studio_display_17.pdf
studio_display_21.pdf
stylewriter.pdf
stylewriter_1200.pdf
stylewriter_ii.pdf
token_ring_products.pdf
twentieth_anniversary_mac.pdf
twopage_monochrome_monitor.pdf
update.21.pdf
update.asd.pdf
update.pdf
video_cards.pdf
video_conferencing.pdf
workgroup_server_9150.pdf
jt [8]
Trash Hauler: call sign: eight-ball
C.O. AC130H SpecOps 68kMLAAF
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
