Jump to content
Sign in to follow this
Teraforce88
LC II Restoration project
Recommended Posts
Greetings,
With the coronavirus pandemic going on and my governor giving a shelter-in-place order as a result, I've been furloughed from my job, which has given me time to finally begin restoring my Macintosh LC II that my family bought new in 1993.   About 5 years ago, I posted a video on YouTube showing a problem that it had regarding the video output:
<iframe width="560" height="315" src="https://www.youtube.com/embed/vtpZmFiManc" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Three years later, the power supply died.  It kept making a faint ticking sound, which corresponded to a faint clicking from the speaker.
A few days ago, I re-capped the power supply.  The LC II works again, but the flickering jailbars are still present.  They behave *slightly* differently, though.  It seems that their flickering can be affected by both hard drive activity and floppy drive activity, which I didn't notice before.  I do see some electrolyte on the motherboard, so I still need to re-cap the motherboard, but I'm wondering if I'm still having some PSU issues?  I ask because:
1.  The fact that the flickering jailbars can be affected by the floppy drive and/or hard drive
2.  When I measured the voltages from the power supply with it disconnected from the motherboard, the +5 and +12 lines looked good, but the -5 was jumping between -3 and -3.8 volts.  During this time, it was making the same ticking sound that it made when it died, but when I plugged it in the LC II's motherboard, it seemed to work fine (I haven't measured the voltages from the PSU while it's plugged into the motherboard)
3.  Over the last few days, I've had my LC II powered on for about 6 hours.  The hard drive has been running perfectly fine while opening various programs, files, and folders except for one time, where the hard drive slowed down for a second when I opened up a folder, then sped back up.  The LC II froze during that second, but then carried on.
My next plan of action is to re-cap the motherboard, but I would like to know if there actually is something wrong with the -5V line on the power supply, or if I just need to measure it while it's plugged into my LC II.
Everything else works fine on the LC II except for the microphone jack, which appears to be dead now.
Thanks,
Share this post
Link to post
Share on other sites
Recap the motherboard. The -5 volts isn't as necessary as it seems - my LC II is only given +5 and +12 volts, and I can print to an ImageWriter II, and sound works fine. -5 volts might be necessary for some serial stuff, depending on what it's connected to, but it wouldn't be the cause the issues you're having.
Share this post
Link to post
Oh, interesting.  My understanding must be wrong.  Maybe it's used for the differential signalling on the serial line and the ImageWriter doesn't need that?  Rampant speculation on my part.
Anyway, yeah, @Teraforce88, it isn't the -5v line :-)
Share this post
Link to post
Thanks for advice, everyone!  I apologize for not posting for a while.   I pulled off the Apple //e emulator card to reveal the caps, and boy oh boy is there some corrosion or what (see attached pic).  There's even a trace or two on the board that appears to be darkened because of the corrosion.  I remember trying to clean the corrosion off several years ago with Q-tips and rubbing alcohol, but that didn't seem to make much of a difference.
I'm going to go ahead and order some capacitors off of Digi-Key, but I still have a few questions:
1.  Since these are surface-mounted capacitors, what's the best way to remove them?  I think the safest way is to use two soldering irons, which I don't have.  PotatoFi mentioned the "Twist and Push" method when he was removing the caps from his LC II; can someone elaborate on how this is done?  Or should I go ahead and just buy a 2nd soldering iron?  I just don't want to rip any solder pads.
2.  What's the best way to clean the corrosion off the motherboard, particularly under the various ICs?
3.  PotatoFi replaced his electrolytics with tantalum capacitors.  Aside from appearance, is there any advantage to sticking with Electrolytics as opposed to converting to tantalum?
Share this post
Link to post
"Twist and Push" method is just grabbing the capacitor can with a pair of needle-nose pliers, pushing down, and twisting it a little bit back and forth until the leads inside the can fatigue and break. If the plastic base of the cap is left behind, remove it with tweezers. You'll also have to desolder what remains of the leads from the board.
The "two soldering irons" method isn't the worst, but it's definitely not the safest either. Bear in mind that excessive heat can lift pads very easily.
Share this post
Link to post
It's perhaps the thing of holy wars, or simple personal preference, but here's some advantages I can see:
- Circuits were likely designed with electrolytics in mind. Tantalums have some different properties.
- Electrolytics tend to fail open, not short, as proven by time and history. Cap goo is bad, but a short may be extremely bad. Unclear if tantalums are more likely to fail short.
- Tantalums feel a bit more 'uncertain' in the longrun.
- You can get the exact pad fit of the factory caps with electrolytics.
The electrolytics in these old machines were relatively new technology at the time. Modern caps, especially more-expensive long-life ones, should last a whole lot longer. I landed on the Nichicon UCB ("Long Life Assurance") and UCW ("Low Impedance, Long Life Assurance") lines for the recaps I am currently diving into.
This all said, there are people who have been doing this much longer than me who choose to use tantalums.
Share this post
Link to post
Interesting!  I had no idea that excessive heat could lift the pads.  I did see a video where someone used a hot air gun to desolder the capacitors on a Mac Classic II, and it seemed to work well for him:
https://www.youtube.com/watch?v=SjgWo7mj8-w
I also saw this video, where you apply solder to each pad, then heat the pads up to lift the caps, but I'm afraid that would lift the pads.
https://www.youtube.com/watch?v=mMMT1qLMX28
How do you guys feel about these methods?  Or should I just stick with "Twist and push"?
Edited by Teraforce88
Share this post
Link to post
If you actually have a hot air rework station, the risk you run using it over dual soldering irons is considerably lower. Emphasis on the "rework station" part; the kind of heat gun you find at the hardware store isn't really optimal for this kind of work. Heating and lifting each side of the cap as shown in the second video is very likely to lift the pads on a board as corroded as yours.
Also, to answer your question about cleaning the board: my personal preference is to fill a plastic tub with tap water and dish soap, put the board in, gently scrub with a toothbrush, and rinse the board with distilled/deionized water.
Share this post
Link to post
Reading this entire thread is what sold me on push & twist:
Try to find some junk boards with similar SMD caps to practice the whole process on, including cleaning the pads and soldering on the new ones. I was able to find some in an old cable modem and dead HDD controller in my junk bin.
Edited by dzog
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
