Jump to content
ardweebno
Quadra 650 refuses to boot internal drive!
Recommended Posts
Hello Liberators!
I recently bought a new-to-me Quadra 650 that came with an original 230MB Quantum SCSI drive.  After unboxing, the Quadra booted exactly one time before the hard drive died.  I bought a replacement 4.3GB Seagate Barracuda SCSI drive (DEC firmware, if that matters), installed it and booted from a System 7.6 Disk maintenance floppy.  I can see the disk with Disk Utility (and SCSI Probe 3.5) and verified it's on ID 0.  I did a full fresh install of System 7.6 on the new drive, rebooted and got a "Happy Mac" followed by Floppy Disk question mark.
I happened to have a Jaz drive laying around with a bootable System 7.6 image on it, popped that in the external SCSI port and the computer booted up fine.  At least I know the SCSI chip is good.  Also, while I was running off of the Jaz drive, I re-verified through Disk Setup that the Apple HD driver was installed (v8.0.8) on the 4.3GB drive.  I don't get it.  Why can I see this SCSI drive, write tons of data to it, but it is still not bootable?
Things I have tried:
* Zapped the PRAM (however, the PRAM battery is dead...)
* Swapped multiple known-good SCSI cables
* Tried with nothing else on the SCSI bus but the new hard drive.
* Tried with nothing else on the SCSI bus but the new hard drive AND a SCSI terminator
* Initialized the drive multiple times, updated the driver and then ran Disk First Aid to verify the disk was setup correctly
* Installed multiple versions of System 7.5.5, 7.6, 7.6.1 and 8.0 to the drive.  None were bootable.
* Ran MacTest Pro from the Jaz drive to verify the new drive, logicboard, RAM and system files are good.
I am at a loss.  Any help is appreciated!
Share this post
Link to post
Share on other sites
Try a smaller partition < 2GB; how are you installing the OS?  Check the 4.3GB drive is internally terminated.
Share this post
Link to post
Isn't the drive limit in 7.5.5—8.0 just 4,063 MB, rather than 4.3GB? As Byrd says, I'd try a smaller partition.
Having said which, I can't understand why formatting and an installation would go so swimmingly on an oversized drive that cannot serve as a boot drive.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
