Jump to content
pcamen
475 boots but then hangs
Recommended Posts
I've got a stock 475 that up until recently, worked perfectly.  It has the original HD in it.  Now, when I boot, right before it is done, a dialog pops up that never fully displays, and the mouse freezes.  I've tried starting with extensions disabled, same thing.  I've checked the startup folder and there is nothing in there.  I can boot from an external SCSI2SD just fine, and see the internal hard drive just fine.  I was able to copy all the contents off the internal HD without errors.
Any ideas?
Share this post
Link to post
Share on other sites
Doesn't TechTool Pro have the ability to repair system folder, and specifically Finder errors? But I'm kinda of LaPorta's opinion. If you've backed up vital data, a re-install might be good due diligence.
Share this post
Link to post
No problem. It fixed my "Melory" control panel issue (Memory was misspelled in the Apple Menu and wouldn't open it, though the control panel was just fine).
I'm curious. Did it say specifically what it fixed?
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
