Jump to content
Forums
  1. Important Information
    1. The 68kMLA Forum Rules   (9936 visits to this link)
      To quote vintage Apple manuals: "Read Me First!"
  2. Community Connections
    1. General 68kMLA News & Stuff
      3971
      posts
    2. Conquests
      39259
      posts
    3. Trading Post
      52386
      posts
  3. Projects & Hosted Forums
    1. RetroChallenge
      http://retrochallenge.org/
      1484
      posts
    2. 68kMLA Wiki
      The creation and maintenance of the 68kMLA's information repository.
      http://68kmla.org/wiki/
      483
      posts
  4. 68k Model Forums
    1. Compact Mac
      Macintosh, 512k, SE, etc.
      45177
      posts
    2. Mac II, Quadra & Centris
      12878
      posts
    3. 68k LC & Performa
      Ah, the consumer computers!
      7887
      posts
    4. 68k PowerBook
      9733
      posts
  5. PowerPC Model Forums
    1. NuBus Power Mac, LC & Performa
      2636
      posts
    2. PCI Power Mac & Performa
      5856
      posts
    3. G3/G4/G5 Power Mac, iMac & eMac
      13686
      posts
    4. PPC PowerBook & iBook
      8950
      posts
  6. Everything Else…
    1. Apple I, ][, /// & Lisa
      7313
      posts
    2. Newton
      1063
      posts
    3. Software
      17343
      posts
    4. Hacks & Development
      18345
      posts
    5. Peripherals
      14427
      posts
  • Posts
    • Hi all!   Just finished my first recap of an SE/30 - was quite the job, but it works! This is my first SE/30 so trying to learn what's possible for my machine.   Now I need to find some ram. I only have 1mb in it currently, so no system 7. My goal would be to have System 7.5.5 on it - I do have a network card so I'd like to go online/transfer files/etc.   OWC has new 16mb modules - And 64mb seems overkill. - 64mb(16x4) $48 - $0.75/mb   Ebay/etc have a lot of 4mb though they'd cost about 2x more per mb as OWC. I don't see any 8mb 30pin simms for sale. - 16mb(4x4MB) $25 - $1.56/mb (2x OWC price per MB) - so if i got 8x4(32mb) would cost more than the 64mb option   I would like to have 16-32mb, but 64 seems overkill.   My questions are: I need to install in sets of 4 - correct? If I'm over 16 mb can the se/30 boot up still? or does MODE32 need to be installed first? Am I missing something or should I just buy the 64mb from OWC (though I hear booting RAM checks can take a while) Would it be a good idea to get a BMOW ROM-inator? (or only if I go with 64mb?)
    • I have a fairly generic KVM with DVI/USB interface that defaults to 1024x768 resolution, e.g., if a machine is booted or if it wakes without the switch being properly set to it. The machines involved are 3xG5s and one Mac Pro running X.5 and X.9 respectively, and all are connected via the KVM to a 1920x1200 Apple Cinema 23" display.   If any one of these machines is not started up or wakened with the switch set to it, I get a blank screen, requiring that the machine be put to sleep by the power button and then re-awakened with the KVM button properly set -- at which point, the proper resolution is recognized through the KVM and all is well. When the screen is blank, furthermore, it is possible to use another Mac and the screen sharing option in networking to access the Displays Control Panels on the affected machines, which shows that the machine knows it is connected to a KVM which requires a 1024x768 resolution. Except it doesn't, and I can't see a bloody thing.   As I have a sort of workaround in the sleep/wake solution, all this is not a total disaster, but it is a small frustration and I wonder if things could be better. Is there some way to force a machines' resolution output to 1920x1200, no matter what screen it thinks it is connected to?
    • I suppose the question would be, what difference would this make on a 68040 over against a 68030 processor? Or between the Q950 and Q700? Smoother serial and floppy operations only?
    • Some update:   On machine A (soldered CPU, recapped and washed now) I found two broken traces to near audio circuits, that would explain no audio at startup. But I haven't seen anything related to video issue. Maybe I'll fix the audio traces first and then I might be able to head some dead mac chime.   On machine B (socketed CPU, washed once, not yet recapped) I get chime from headphones and it seems to start up. But only if I hold the power button down all the time and event then the startup fails sometimes with clicking.   On machine C (socketed CPU, washed once, not yet recapped) there are some professional looking jumper wire fixes and sticker indicating some service work. The board seems to be made in a different factory as the silkscreen printing differs a bit from other two. Also blue "blob" filters used instead of green "worm" ones. This one requires startup from power button of the board but doesn't require holding it down all the time.
    • Holy smokes that is an absolutely baller Cube. Congrats!       Huxley
