Jump to content
Forums
  1. Important Information
    1. The 68kMLA Forum Rules   (10106 visits to this link)
      To quote vintage Apple manuals: "Read Me First!"
  2. Community Connections
    1. General 68kMLA News & Stuff
      3972
      posts
    2. Conquests
      39513
      posts
    3. Trading Post
      52997
      posts
  3. Projects & Hosted Forums
    1. RetroChallenge
      http://retrochallenge.org/
      1486
      posts
    2. 68kMLA Wiki
      The creation and maintenance of the 68kMLA's information repository.
      http://68kmla.org/wiki/
      497
      posts
  4. 68k Model Forums
    1. Compact Mac
      Macintosh, 512k, SE, etc.
      45886
      posts
    2. Mac II, Quadra & Centris
      13029
      posts
    3. 68k LC & Performa
      Ah, the consumer computers!
      7954
      posts
    4. 68k PowerBook
      9856
      posts
  5. PowerPC Model Forums
    1. NuBus Power Mac, LC & Performa
      2671
      posts
    2. PCI Power Mac & Performa
      5881
      posts
    3. G3/G4/G5 Power Mac, iMac & eMac
      13721
      posts
    4. PPC PowerBook & iBook
      8965
      posts
  6. Everything Else…
    1. Apple I, ][, /// & Lisa
      7390
      posts
    2. Newton
      1066
      posts
    3. Software
      17461
      posts
    4. Hacks & Development
      18537
      posts
    5. Peripherals
      14524
      posts
  • Posts
    • Given the kick to the system bus, is it worth upgrading from say a G4 500mhz to a G4 1Ghz?
    • I'm not sure about the serial numbers, but the Lisa 1 mice had a very narrow button vs the newer ones that were shared with the Mac and Lisa 2's, and also a different DB9 connector hood (no screws). see the photos here: https://www.worthpoint.com/worthopedia/apple-lisa-mouse-a9m0050-early-013519-1863798648   There's a few of these on ebay that are super expensive as well.   There is a formula for the serial number of Lisas that tell you the manufacture date and plant in a document called "Good Things To Know About The Lisa.pdf" from SunRem, but not sure that a similar scheme applies to the mice. It does appear that the newer mice that came with the Mac 128 to the plus had a different serial number scheme than what's on the Lisa 1 mice. And to add more confusion, they all have the same model number.   I wouldn't go by the serial number as much as the shape.
    • Yep here it is, Technical Introduction to the Macintosh Family p. 227:   ”Note: On the older 400K disk drives, a buffer in RAM (actually the low-order bytes of words in the sound buffer) is read by the Analog Signal Generator (ASG) to generate a pulse-width modulated signal, like the sound signal, that controls the speed of the disk motor. This speed variation is responsible for the characteristic humming of the disk drive. The Macintosh Operating System uses this speed control to store more sectors of information in the tracks closer to the edge of the disk by running the disk motor at slower speeds. On the BOOK drives, the variable disk speed is automatically controlled by the disk drive hardware.”   https://vintageapple.org/macprogramming/pdf/Technical_Instroduction_To_The_Macintosh_Family_1987.pdf
    • You need to recap it before you do ANYTHING with it period.    These logic boards are known for failing catastrophically with bad caps. Sometimes to the point where you end up the waiting queue for a replacement logic board as a few others are in.
    • the convergence could have been brought back into alignment much easier by adjusting the H-STAT control on the CRT Neck PCB.
