Jump to content
joshc
Macintosh Plus (originally 128K) International Analog board capacitors / components
Recommended Posts
I have a 128K which was upgraded back in the day to a Plus. It has the 128K front and the Plus 1MB back case. Logic board and Analog board are Plus parts.
It powers on but has no video. I suspect some worn out components on the analog board.
Straight away upon inspection - the C1 capacitor is bulging badly at the top, and leaking at the bottom. So I've removed that, and now I'm finding it hard to find a replacement!
The capacitor says 35 V 3.9 uF (M) on it.
The analog board is part number 630-0108 - it's stamped with 'International'. (I'm in the UK...)
I checked this well-circulated list of components for the analog board, but it says C1 is 3.9µF 100V. However this list seems to be for U.S. analog boards only...
https://docs.google.com/spreadsheets/d/132RwzC8HM5ask-BdY_31txErOCwJDSkz099GY2XLpE0/edit?hl=en&hl=en#gid=0
So does the International version of the board use a lower voltage capacitor, or are they interchangeable ?
I also removed the two RIFA film capacitors, as they looked ready to explode and are badly cracked. These are marked RIFA 4700pF PME 271 Y 250V~SH . What can these be replaced with?
Photos attached if it helps.
Thanks in advance.
Edited by joshc
Share this post
Link to post
Share on other sites
Woops, I might have answered my own question with the paper capacitors...I am fairly certain these are the correct replacements. Unless anyone knows of a more robust component to replace them with?
https://uk.farnell.com/kemet/pme271y447mr30/cap-4700pf-20-paper-radial/dp/9717552?scope=partnumberlookahead&ost=PME271Y447MR30&searchref=searchlookahead&exaMfpn=true&ddkey=https%3Aen-GB%2FElement14_United_Kingdom%2Fw%2Fsearch
Share this post
Link to post
Potential replacement for C1?
https://www.mouser.co.uk/ProductDetail/United-Chemi-Con/EKXE401ELL3R9MH15D?qs=sGAEpiMZZMvwFf0viD3Y3fHxNcSaiftwx%2B5cRnxFQPSqFS4oBxuzkQ%3D%3D
Seems like its OK to change to a higher voltage as I believe that's an upper limit? This is also 105 C vs the original 85 C rated one so should last a bit longer perhaps.
I'm still keen to hear from others here regarding what you've used for the C1 capacitor on your Plus analog board.
Share this post
Link to post
I haven't actually done my Pluses yet, but I was planning to use a ~100V cap personally since that's what I have in my big drawer o' capacitors (I too am in the UK).  I don't think it matters unless the rated cap voltage is *stupidly far* above the voltage at point of use.
That said, I'm by no means an expert...
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
