Jump to content
Zelf
Issues to format SCSI external HDD on a Macintosh Plus
Recommended Posts
Hi 69kmla community!
Having some trouble figuring out how to format and initialise an external SCSI HDD (GCC Technologies UltraDrive 45) with Apple HD SC setup 2.0.3 on a Macintosh Plus from 1986 with 4MB of RAM.
I read elsewhere that i need HD SC setup version 3.0 to recognise non-Apple SCSI external HDD to boot on it the system.
And that 3.0 version work with System 7.0. I have System 6.0.8 on a DD Floppy Disk.
The external 45MB HDD use 50pins connector with a passive SCSI terminator.
The lights blinks when Mac Plus boot up and trying to find System files and also when trying to search for SCSI drives with Apple HD SC Setup but never recognised.
So i need an DD 720k disk with HD SC Setup and another one with System 7 to start formatting this non apple hdd?
Thank you, restoring this gift.
Share this post
Link to post
Share on other sites
You need the patched version. The vanilla one won't work with this HD.
https://macintoshgarden.org/apps/apple-hd-sc-setup-753-patch
I hope you have a Floppy EMU or a bridge mac to create 800k disks...
Share this post
Link to post
Interesting, no. But maybe if i search for someone on the island of Montreal i could find to help before buying the device. I wonder if i should invest that much...
15 minutes ago, bibilit said:
I don’t think the connector on the back is a proper terminator
Ok, i am new to SCSI. But if not a terminator what is its prurpose?
Male/female 50pins it just extend the cable ? Doesn't make sense for me.
Yes the hard drives is responsive right green led always on, left yellow led flick only when i scan for SCSI drives.
Thx for the cue!
Share this post
Link to post
Can be was is called a pass through terminator.
So should work as a terminator, have one of those in a drawer, never used myself.
The Plus is picky with Scsi, and only the very last logic board is playing ok with it.
I will try to format the drive with another machine, then connect it back to the Plus.
Keep in mind that the Plus will require also to set the interleave properly (3:1)
Share this post
Link to post
Ok thx!
It was originaly owned by the parents of a friend and it came all together in a box. I guess they surely worked well together in the past.
Unless i need a proprietary driver from GCC Technology.
Interleave... is it related to the symetric/asymetric write/read modes ? (forgot where i read about it, but probably a SCSI wiki page of some sort).
Edited by Zelf
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
