Jump to content
Forums
  1. Important Information
    1. The 68kMLA Forum Rules   (10390 visits to this link)
      To quote vintage Apple manuals: "Read Me First!"
  2. Community Connections
    1. General 68kMLA News & Stuff
      3980
      posts
    2. Conquests
      40022
      posts
    3. Trading Post
      54375
      posts
  3. Projects & Hosted Forums
    1. RetroChallenge
      http://retrochallenge.org/
      1490
      posts
    2. 68kMLA Wiki
      The creation and maintenance of the 68kMLA's information repository.
      http://68kmla.org/wiki/
      549
      posts
  4. 68k Model Forums
    1. Compact Mac
      Macintosh, 512k, SE, etc.
      47292
      posts
    2. Mac II, Quadra & Centris
      13575
      posts
    3. 68k LC & Performa
      Ah, the consumer computers!
      8247
      posts
    4. 68k PowerBook
      10254
      posts
  5. PowerPC Model Forums
    1. NuBus Power Mac, LC & Performa
      2715
      posts
    2. PCI Power Mac & Performa
      6003
      posts
    3. G3/G4/G5 Power Mac, iMac & eMac
      13821
      posts
    4. PPC PowerBook & iBook
      9107
      posts
  6. Everything Else…
    1. Apple I, ][, /// & Lisa
      7494
      posts
    2. Newton
      1074
      posts
    3. Software
      17650
      posts
    4. Hacks & Development
      19631
      posts
    5. Peripherals
      14903
      posts
  • Posts
    • There are no disadvantages to implementing >4GB images.  This is something 040 and PPC owners have been interested in, in addition to the CD audio and changer functions.  For example, you could use fdisk to divide a 32GB card into a 20GB FAT32 partition and a 12GB hard drive image.  A drive entry in the config file could point to an image file on the FAT32 partition or to the entire 12GB partition.       That is the general idea, but not a direct quote.      While my primary focus is Macs, there's no reason MacSD cannot work on other SCSI platforms.  It is being tested on Amiga, SGI, Sun, RS/6000, etc by others.  I will describe it as unsuitable for applications supporting human life (as are its individual components and the SD card).  Nobody should be using this in a traffic light.  Everything else is fair game.
      I'm not concerned whether features I add to MacSD already exist in other products.  Everyone benefits from the new options and capabilities.   The ini file configuration in no way limits the MacSD's capabilities.  Config files run entire operating systems.  In addition to convenience, it solves the problems of: Keeping firmware and configuration utilities updated in tandem Migrating configuration on firmware updates On-chip configurations valid only for a particular card   If you don't want to bother with >4GB images and fdisk; if all you need is a single HDD, your config file is two lines long.  Easy is not the opposite of powerful.
    • That is truly staggering and it seems that it was well cared for e.g. carefully packed and kept reasonably clean.  Congrats!
    • If I'm interpreting what this device does that explicitly makes it Mac-friendly correctly, that depends on the Apple IIgs working well with the same SCSI devices Macs use. However, for IIgs there are also lots of other extant options including the focus IDE card (what I've got in mine), floppyemu, which will run smartport HDs on the II, and CFFA, which operates on a somewhat similar concept to this, except that it has an inline control panel for image swapping.   @ymk - welcome in!   With regard to >4GB images, I'm curious what the demand for that is like. Only '040 Macs will officially run volumes over 4GB, and your'e kind of getting closer at that point to the brief window where the SCSI2SD v6 makes more sense, for performance reasons, and then after that, where SATA cards make more sense. I can imagine a couple use cases for it, myself, but I'm also among the relatively few people I'm aware of running 2TB volumes  Classic Mac OS at all. (Although, like,    With regard to partitioning, what would that look like in terms of setup and configuration? It would seem like the biggest advantage you've really got here is that this device was "designed with the needs of the vintage Mac community in mind", I feel like it would be fair to describe it as explicitly to the exclusion of other platforms and applications where scsi2sd is also used (i.e. it's unlikely one of these will work in a synthesizer or a traffic light or a UNIX machine) and a big part of that is the simplicity afforded by the way this thing is configured.   The people among us creating SCSI2SD preloads would be able to change to just zipping up the contents of the FAT32 filesystem as a download and people can avoid, say, DD or managing partitioning entirely.   If this is in the docs, you can be like "hey, uh, RTFM" and I will at some point. I don't have the budget for one of these so this is purely speculation on my part.
    • All eight of the indicator LEDs on the edge can be mirrored to external LEDs.  Nine pins on the expansion header can be used for LEDs (eight anodes and a common cathode).     I've done no testing with Apple II.
