Jump to content
Sign in to follow this
giolicious
Will the Macintosh Plus M0110A keyboard work on a Mac128K?
Recommended Posts
I haven't actually tried this, but I'm sure it will work -- the only question would be if you were using a very early version of the OS from before that version of the keyboard existed. I'm not sure about the numpad/arrows in that case.
Edited by Mighty Jabba
Share this post
Link to post
Share on other sites
Correct. The arrow keys and some of the other keys which the Plus keyboard added are dependent on System file support. As long as you're using System file version 3.0 or later (1986), you should be fine.
You can also copy the appropriate INIT resources from a newer System file into an older System file, if need be.
Share this post
Link to post
That’s interesting @Dog Cow.  I trust you, recall similar things (arrow key support in TextEdit wasn’t documented until Inside Macintosh Volume IV, for example) and haven’t tried mine with older System Software, but ... the numeric keypad available with the 128k Mac in 1984 had arrow keys.  Did they not do anything?  Or require dedicated application support through GetKeys() or similar?
Share this post
Link to post
Those technically weren't arrow keys, and instead Apple called them "field motion keys." They work in Microsoft Multiplan and probably other spreadsheet applications. See Inside Macintosh, volume 1, page I-36.
By the way, the Macintosh can tell whether a keypress came from the main keyboard or from the keypad, even if it's a key which is common to both.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
