Jump to content
Forums
  1. Important Information
    1. The 68kMLA Forum Rules   (10128 visits to this link)
      To quote vintage Apple manuals: "Read Me First!"
  2. Community Connections
    1. General 68kMLA News & Stuff
      3972
      posts
    2. Conquests
      39565
      posts
    3. Trading Post
      53116
      posts
  3. Projects & Hosted Forums
    1. RetroChallenge
      http://retrochallenge.org/
      1486
      posts
    2. 68kMLA Wiki
      The creation and maintenance of the 68kMLA's information repository.
      http://68kmla.org/wiki/
      499
      posts
  4. 68k Model Forums
    1. Compact Mac
      Macintosh, 512k, SE, etc.
      45997
      posts
    2. Mac II, Quadra & Centris
      13106
      posts
    3. 68k LC & Performa
      Ah, the consumer computers!
      7962
      posts
    4. 68k PowerBook
      9872
      posts
  5. PowerPC Model Forums
    1. NuBus Power Mac, LC & Performa
      2672
      posts
    2. PCI Power Mac & Performa
      5881
      posts
    3. G3/G4/G5 Power Mac, iMac & eMac
      13741
      posts
    4. PPC PowerBook & iBook
      8967
      posts
  6. Everything Else…
    1. Apple I, ][, /// & Lisa
      7398
      posts
    2. Newton
      1066
      posts
    3. Software
      17464
      posts
    4. Hacks & Development
      18623
      posts
    5. Peripherals
      14548
      posts
  • Posts
    • Just curious, no criticism implied:   Bodge (To do a clumsy or inelegant job, usually as a temporary repair; mend, patch up, repair.) has the wrong connotations for factory rework, which is very different today. It was an accepted industry practice some 30 years ago. PCB costs were high and skilled labor for testing and doing such fixes to 10mil/5mil tech PCBs was available and relatively inexpensive. While not elegant, rework patch wiring was done to a high standard as a permanent solution for design flaws, batch production glitches and individual boards that failed testing. The trace fixes we regularly do today "to mend, patch, repair" our damaged boards would not be considered bodge wires if done in a workmanlike manner, while fugly fixes would.    Are the connotations a bit different in the Netherlands? Very curious about that. Wictionary: Middle Dutch botsen, butsen, boetsen (“to repair, patch”)
    • It's not that bad a throughput, given that you've got two sets of encapsulation and very small packets going on.  How fast do you get over AFP/DDP?
    • Hmm, that's weird.   I don't know much about this, but I think I've read in passing (while attempting to solve other problems) that symptoms like this can be indicative of either failed resistors or diodes somewhere in the affected circuit.   I guess you could check for burnt R's and D's and replace any that you find?  It could be as simple as a broken solder joint too, so check any connections for continuity while your at it.
        c
    • Isn't that why we all use these archaic machines?   This is a painfully slow method of moving files, about 3 minutes a Mb. I guess it would still be faster than writing a Mb to a floppy and then loading the floppy into another machine. It's slow enough that the SE/30 is able to be used for light games while the transfer is happening, though it hanged when I tried to pay a second game of Spades.   I have a few options for sneaker net, but for moving a file or two, this will likely work good enough until I find the SCSI to ethernet bridge. I don't know for certain the accelerator works, so I don't want to dump a bunch of money into this idea just yet. I figure this solution can also be used with my Plus and a Powerbook 165, possibly all at the same time if I get enough phonenet adapters.   J White
    • Great to hear @Ton but given that the engineer I talked to before deciding to do this mod repairs PSUs for a living and tests them at full load for 24 hours before calling them fixed, I wouldn't declare victory just yet... My recapped PSU died during a small stress/smoke test. My plan was to leave it on idling for 3 or 4 of hours but it didn't even pass the two hour mark...      But your problem is interesting: it means that computers of this era (early 90s) are starting to suffer from tantalum cap failures. Instead of leaking like the electrolytic ones do, those just explode.    ________________________   And now, back to the subject at hand. I have once again decided to change the fan controller (this will be the last time, as I'm sure this will work this time). I just can't get enough from the 555 to do everything it want it to do. I'll now be using an Arduino Nano board (it costs from 1 to 7 bucks depending on who you're getting it from... even clones from China should do the job).   I chose it because: 1/ It comes in a PDIP like package. Either solder it to the QuadrATX DC board or install it in a socket. You don't need a hot air station... 2/ It's configurable, because it'll be running a bespoke sketch (read program). If I mess up the code, I can still change it without having to alter the DC board. 3/ It's REALLY easy to flash. Get the free Arduino App for your Mac/Linux/PC, open it, plug in the Nano with a USB cable and hit upload. ANYONE CAN DO IT.  4/ If it dies, there's plenty more available 5/ It's easy to program for and it's got quite a sizable community. 6/ The fan controller part of the schematic is now a lot easier to understand and the circuit won't take as much space on the DC Board as it used to.  7/ Isn't that enough?   More to follow...
