Jump to content
Forums
  1. Important Information
    1. The 68kMLA Forum Rules   (10164 visits to this link)
      To quote vintage Apple manuals: "Read Me First!"
  2. Community Connections
    1. General 68kMLA News & Stuff
      3973
      posts
    2. Conquests
      39584
      posts
    3. Trading Post
      53159
      posts
  3. Projects & Hosted Forums
    1. RetroChallenge
      http://retrochallenge.org/
      1486
      posts
    2. 68kMLA Wiki
      The creation and maintenance of the 68kMLA's information repository.
      http://68kmla.org/wiki/
      502
      posts
  4. 68k Model Forums
    1. Compact Mac
      Macintosh, 512k, SE, etc.
      46148
      posts
    2. Mac II, Quadra & Centris
      13176
      posts
    3. 68k LC & Performa
      Ah, the consumer computers!
      7968
      posts
    4. 68k PowerBook
      9906
      posts
  5. PowerPC Model Forums
    1. NuBus Power Mac, LC & Performa
      2672
      posts
    2. PCI Power Mac & Performa
      5884
      posts
    3. G3/G4/G5 Power Mac, iMac & eMac
      13750
      posts
    4. PPC PowerBook & iBook
      8971
      posts
  6. Everything Else…
    1. Apple I, ][, /// & Lisa
      7400
      posts
    2. Newton
      1066
      posts
    3. Software
      17469
      posts
    4. Hacks & Development
      18691
      posts
    5. Peripherals
      14563
      posts
  • Posts
    • No, it is most certainly NOT normal. Voltages should climb up nearly instantly and remain steady at all times. There are many things in this power supply known to cause issues, and I remember running into a handful of threads where stability issues were being caused by a specific component that other members were trying to find functional substitutes for. I forget which threads they were, its been years.
    • So, you're telling me that fluctuating voltage isn't normal? Well that's a start, now let's find the problem! What could go wrong with the power supply? I'm no expert in electrical circuits, but my tip is on the T3 transformer, last time I checked, it looked kinda fried up.
    • Then that click-click sector is a bad sector. It needs to be mapped in the bad table. Not sure how you can do that with Mac software, but I know you can do that with PC software. Once all known bad cylinders are stored in the preformatted bad table, that blocks them off from OS tools being able to use it. Then the drive will skip over that sector every time.
    • And there is your problem. You still have power supply issues that you need to Iron out.
    • Woo, worked out the graphics issue - the monitor didn't like been overclocked that hard from the IIx. It is usually ok at 75hz, but for some reason it wasn't here.   At the moment I've found that it runs at 72hz in 800x600... still technically too fast, but the screen copes.   Just disk and possibly pram issues now! So close! From dead to photoshop in ~3 weeks!
