Jump to content
Sign in to follow this
EvieSigma
How to open up a 7100?
Recommended Posts
I've never owned any of the machines in the IIvx case before and now I have a 7100/80. Unfortunately my hard drive seems to be bad, and I don't really know how to open the machine up beyond sliding off the top cover. How does it work?
Share this post
Link to post
Share on other sites
Not complicated at all.
Just unscrew the big flat-head screw recessed on the tip of the rear of the case.
Slide the casing back, then lift up fro. The rear and towards you.
That's it.
To remove the HD, just unplug the cables and there should be a Philips/posi screw that holds the HD to the case and just undo that and it should come out with the caddy/holder.
Share this post
Link to post
Yeah, gave the machine a thorough check. Motherboard is filthy but okay, hard drive is unfortunately completely dead. I'll have to dig up some 72pin EDO and upgrade it from it's current 16MB.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
