Jump to content
Forums
  1. Important Information
    1. The 68kMLA Forum Rules   (9918 visits to this link)
      To quote vintage Apple manuals: "Read Me First!"
  2. Community Connections
    1. General 68kMLA News & Stuff
      3971
      posts
    2. Conquests
      39208
      posts
    3. Trading Post
      52337
      posts
  3. Projects & Hosted Forums
    1. RetroChallenge
      http://retrochallenge.org/
      1483
      posts
    2. 68kMLA Wiki
      The creation and maintenance of the 68kMLA's information repository.
      http://68kmla.org/wiki/
      483
      posts
  4. 68k Model Forums
    1. Compact Mac
      Macintosh, 512k, SE, etc.
      45151
      posts
    2. Mac II, Quadra & Centris
      12859
      posts
    3. 68k LC & Performa
      Ah, the consumer computers!
      7882
      posts
    4. 68k PowerBook
      9725
      posts
  5. PowerPC Model Forums
    1. NuBus Power Mac, LC & Performa
      2636
      posts
    2. PCI Power Mac & Performa
      5856
      posts
    3. G3/G4/G5 Power Mac, iMac & eMac
      13676
      posts
    4. PPC PowerBook & iBook
      8950
      posts
  6. Everything Else…
    1. Apple I, ][, /// & Lisa
      7307
      posts
    2. Newton
      1063
      posts
    3. Software
      17335
      posts
    4. Hacks & Development
      18329
      posts
    5. Peripherals
      14409
      posts
  • Posts
    • Here's what the case looked like at the beginning of the day.     I left some water out in a bin overnight, and this morning at 9 or 10 AM it was about 75 degrees.     I dumped in six bottles of 40 proof hydrogen peroxide. I noticed that all of the caps felt really loose on these, and the little sealing thing came off in the cap. It makes me wonder if these were really sealed up...     Sadly, it just didn't get very hot today. I never saw it clear 95°F. The fishtank heater brings it up to 90°F on it's own.     After about 4 hours, I swapped in the back.     Towards the end of the day, I took the rusty chassis and logic board shield over to my brother's shop. He makes AR-15 lowers and accessories, and has a lot of great tools, such as a sandblasting cabinet. I've never used one of these, and found that it's pretty hard to see what you're doing in the cabinet.     Here are the results. He instructed me to not touch the parts - just go home, hit them with compressed air, and apply primer.       Of course, I'm out of masking tape, so to mask off any metal parts that I wanted to keep exposed, I used black electrical tape. You can see a tiny square of it on the chassis. I tried to mask off any parts where I thought connecting grounds would be important.     My brother gave me a can of high-temperature primer. It's designed for headers and other parts for engines... because... you know. Macs get super hot.   But seriously, it's primer. That's all I wanted.     It does seem a bit "blue". I'm trying to decide whether to go buy a can of flat grey, or just put it back together as-is. Let me know what you think.
    • No it's a universal limitation: a non-High Speed -RW drive won't burn a High Speed-rated -RW disc. The same is true regarding Ultra Speed discs and earlier drives, as well: can read but won't write at all. I don't know for sure what's different technically but quick reading suggests it's a difference in laser write output and/or chemicals used in the disc dye across the various generations.   I don't use -RWs a ton but I have a small stockpile of older discs should I need them. It's not easy to find the early -RW discs anymore without mail-ordering some NOS discs or buying from special vendors. Sometimes you'll get lucky at a thrift store.
    • I also soldered in a pin header to use the SE/30's LED with my SCSI2SD. I compared mine side-by-side with my Quadra 700 and though there's some age difference the power LED on the Quadra is definitely green and the activity LEDs are, near as makes no difference the same, and definitely yellow/amber.
    • Yeah looks like I got some bad info on that and jumped to the wrong conclusions. Sorry. Definitely no PCIe signals available at the AirPort Extreme socket in a late 2005 G5.   However if all you wanted was internal BT the rest of my post stands: you can just trace out the 5-10 USB lines and install a USB connector rather than run all of the unnecessary lines and find the special connector and then an adapter for whatever BT module you were planning to install.
    • What a coincidence! I did the same thing today too!
