Jump to content
Forums
  1. Important Information
    1. The 68kMLA Forum Rules   (10165 visits to this link)
      To quote vintage Apple manuals: "Read Me First!"
  2. Community Connections
    1. General 68kMLA News & Stuff
      3973
      posts
    2. Conquests
      39588
      posts
    3. Trading Post
      53161
      posts
  3. Projects & Hosted Forums
    1. RetroChallenge
      http://retrochallenge.org/
      1486
      posts
    2. 68kMLA Wiki
      The creation and maintenance of the 68kMLA's information repository.
      http://68kmla.org/wiki/
      502
      posts
  4. 68k Model Forums
    1. Compact Mac
      Macintosh, 512k, SE, etc.
      46161
      posts
    2. Mac II, Quadra & Centris
      13181
      posts
    3. 68k LC & Performa
      Ah, the consumer computers!
      7968
      posts
    4. 68k PowerBook
      9906
      posts
  5. PowerPC Model Forums
    1. NuBus Power Mac, LC & Performa
      2672
      posts
    2. PCI Power Mac & Performa
      5884
      posts
    3. G3/G4/G5 Power Mac, iMac & eMac
      13750
      posts
    4. PPC PowerBook & iBook
      8971
      posts
  6. Everything Else…
    1. Apple I, ][, /// & Lisa
      7400
      posts
    2. Newton
      1066
      posts
    3. Software
      17469
      posts
    4. Hacks & Development
      18691
      posts
    5. Peripherals
      14563
      posts
  • Posts
    • Alright, I could test the drive using Micronet and found out one bad sector (9569), but using Micronet to reallocate it leads to the clicking noise and a couple of errors. I think I'm done here.
    • That might be true, but let's be realistic, the material seems like plastic and if you look at the analogue board pictures above, you can see the other corners look alike, but the bottom left corner is out of shape, this leads me to believe that it was made to handle certain amount of heat and on that one corner, the amount of heat exceeded the operating temperature and it just melted. So something happened that should not happen normally.
    • If your meter will read really low resistances you can measure the shorted rail in different area's or the board and the reading should get lower the closer to the shorted component you get. I haven't ever done this personally but have seen it done online a few times and it seems to work   Other than that what you have described should work in most circumstances (It's what I would usually do on modern boards) however it will not work on really really low resistance shorts (e.g solder bridges)
    • Very interested in this.   These look easy to copy if you could get the timing right :   https://www.worthpoint.com/worthopedia/4x-4mb-apple-mac-ii-iix-30pin-tin-non-1825526434   Thats a quad or isn't it?
    • So well, not so good as it turns out. As soon as I slotted the batteries in I heard a little "click" noise from the part of the board near the power button or thereabout. Removed the batteries of course...   I got investigating, and there is a short on the main rail! Almost everywhere... that annoyed me a lot as I was very careful but then again... small mistake?   So I started to remove all the caps I replaced (well the SMT ones, I can't see the bigger ones being a problem!) and test until none was left and... no luck, still shorting.   So I think I'm going to also remove the 4 SOIC I installed, and then ----- grrrrr remove all the patch wires. And I still don't know if it will fix it, as I'm not entirely sure the short wasn't there in the first place! How *annoying*.   Next is to try to find the short, I got some freeze spray, and a bench supply of course, so I'll try to put 3V with increasing Amps into it and hope I can see something heat up.. unless someone has a better suggestion?
