Jump to content
Mighty Jabba
Macintosh SE screen flickering/changing shape
Recommended Posts
I just got in another Mac SE and it’s got a bit of a weird problem. The screen will periodically flicker and get larger horizontally by about a cm. Supposedly it was working perfectly before I got it, but it wasn’t packaged very well by the seller and I’m thinking that something may have gotten knocked out of place. I did try adjusting the picture with the potentiometers on the side but it doesn’t seem to affect the fundamental issue. Any ideas?
Edited by Mighty Jabba
Share this post
Link to post
Share on other sites
No ideas on this one? I noticed that it had the old squirrel cage style fan (which is really is quite loud). Somewhere I heard that these fans could potentially cause screen interference, but I don't know if it's related. I'm kind of stumped about where to start diagnosing this since I don't know a lot about CRTs.
Share this post
Link to post
Sorry if I left you hanging.....
J1 is the connector from the deflection coil on the CRT to the analog board.
There are 4 wires, I think I remember that they’ll be red, blue, green, yellow. I don’t remember the order.
Check the solder joints on the analog board at that connector, and check the connector for brown / black, that will come from inside the connector.
If there is brown / black, conditions will only get worse.
Change the connector.
Edited by jimjimx
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
