Jump to content
Sign in to follow this
maz
Making a 20SC disk bootable
Recommended Posts
Hey forum, I've installed system 6 from the original disks onto a genuine SC20, everything works except I can't seem to boot from it. What's the trick? SCSI ID is 3.
Thanks!
-- maz
Share this post
Link to post
Share on other sites
3 hours ago, MOS8_030 said:
If it's a Plus I think the ID needs to be 0.
Plus should boot any ID except 7.
Maz,  Check your Startup Device CDEV if on an SE or newer machine.
Make sure the drive is powered on before you switch on the Mac.
Did you install System 6 with the same Mac you are now trying to boot it with?
Share this post
Link to post
I may be thinking of the early Plus's with the buggy SCSI.
Or I may not know what I'm remembering... ;)
Either way, I believe the drive needs to be terminated as well.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
