Jump to content
joshc
Another eBay conquest, 3 more compact Macs... (aka Mac Haul 2)
Recommended Posts
Hi everyone
This is a little more interesting than my last conquest (I hope!). On the auction, it said that there were two Mac Plus and an SE/30.
So, yep, there are 2 machines which say Plus 1MB on the rear, and an SE/30.
However...on further inspection at one of the Plus models, it has a 128k serial number, and doesn't say Plus on the front. Is this some sort of weird 128k that was sold with a Plus upgrade, or? Hopefully someone can shed some light on what I've just bought!! :embarrassed:
Also, can anyone tell what expansion card is in the SE/30? Looks like a network card to me.
In terms of the state of these 3 machines, I've been told that one of the Pluses (or maybe 128k......) does power on, one has the checkboard problem, and the SE/30 powers on but has no video.
I have a keyboard for the Plus, but no mouse - a quick look on eBay and the only 128k/Plus mice available are in the USA for $$$, so I might have to wait it out to get a mouse...
Thanks in advance! :b&w:
Share this post
Link to post
Share on other sites
OK, I've just tested all 3...and all 3 power on but NONE are showing any video at the moment, the two Plus models chime when they boot, and the SE/30's hard drive spins up and sounds OK but there is no chime from the SE/30 (guessing bad capacitors have killed the audio). So I think these are definitely salvagable but I'm guessing at the moment that they might have bad capacitors on their analog boards as well...
My work is definitely cut out for me, I now have 6 compact Macs to repair...! xx(
Share this post
Link to post
OK, a quick Google revealed this, so I think thats what happened with the M0001 Mac...
"Finally, a Mac 128K could be upgraded to a Macintosh Plus by swapping the logic board as well as the case back (to accommodate the slightly different port configuration) and optionally adding the Macintosh Plus extended keyboard."
I wonder how much Apple charged for this upgrade back then, I wouldn't be surprised if it's not far off the cost of a new Mac at the time.
Share this post
Link to post
6 minutes ago, olePigeon said:
Presumably you had to buy an 800k floppy drive for it.
I think technically the way they priced the upgrade is a "prerequisite" for the Plus upgrade was having the 800k floppy drive upgrade which also included the 128k ROMs, so technically for a full Plus upgrade you were buying two SKUs at once. The drive upgrade was surprisingly affordable as Apple products go at "only" $299, but I don't remember what the Plus board part of it cost. (And google-fu is failing me.) There's one reference out there that the trade-in cost for a 512ke (which already has the drive) was $799, so maybe it was $1100?
Share this post
Link to post
If these were transported at all (shipped, packaged, carried) you might want to check the video connector (and other connectors) to make sure it is plugged in before you declare no-joy on the video. I have gotten a few compact macs that were disconnected at the CRT and simply making sure it was properly plugged in 'restored' the video.  Obviously it won't fix the one with the checkerboard pattern.
Edited by Juror22
Share this post
Link to post
Thanks @Juror22 it's a good shout because on the eBay item, there is a photo of the Plus with its video working fine, so maybe something was dislodged in transit in my car...:undecided:
Thanks for finding out the pricing info @Gorgonops I'm sure with enough Google searching we would probably find the original documentation for Apple's OEM upgrade options.
I sure hope it has a 800K drive, otherwise I have the 'fun' of finding or creating 400K disks...... :O
Share this post
Link to post
There were two upgrade packages for the Mac 128K and 512K:
1.) 128K ROM + 800K drive. You kept your original motherboard. This cost about $300.
2.) Mac Plus logic board upgrade. This required the first upgrade (ROM + disk), and came with the Mac Plus rear case. This upgrade cost $600 and $800 for the 512K and 128K Mac, respectively.
400K disks aren't all that bad. If you have a machine or a drive that can write double-sided 800K disks, then 400K disks will be no problem.
Edited by Dog Cow
better source link for upgrades, better clarification
Share this post
Link to post
Dog Cow, I may not be understanding this, but how could a Mac 128k with 128k RAM be able to support the 128k ROMs without also needing more RAM?
Share this post
Link to post
It does. I've tried it. You get a 128Ke, and you can boot from an HD20 and do HFS stuff. I've seen a few mentions of the "128Ke" configuration from 1980s-era Usenet posts and other sources, showing that it was something people did back then.
I'm still not entirely sure if this was an official Apple-supported upgrade. I do know that Apple was pretty strict with upgrades, required the dealer to do the upgrade, and made him return the old ROMs to Apple. So probably it was an Apple-sanctioned upgrade, just not a very common one in 1986. Regardless, it's an upgrade that some people did, and that does yield a more functional Mac 128K.
I haven't done any in-depth analysis on system heap usage between the 64K ROM and 128K ROM in a Mac 128K, so I can't give you any more details on why it works. It just does. ;-)
Edited by Dog Cow
Share this post
Link to post
1 hour ago, olePigeon said:
Wasn't the original Mac demo that Steve Jobs did a "128Ke" because it didn't have enough ram to run the presentation?
Not quite. It had the original 64K ROM (which was frozen a few months prior, in September 1983), but it had 512K of RAM.
Share this post
Link to post
Thanks for the extra info @Dog Cow I've not had time to examine the board inside the 128K to see if its a Plus board or not, unfortunately thats the one which powers on but has no video.
I opened up the SE/30 and Plus and jiggled things around a bit and now the video works on both of those, but neither boot and the floppies seem to have trouble reading disks and wont eject them properly either.
Progress, kind of, slow progress...
I have ordered a mass of things from Amazon so that I can do proper repairs on all my Macs... SMD soldering/desoldering station, lots of tools, etc etc....stay tuned for more photos/videos!
Edited by joshc
Share this post
Link to post
My vague recollection is that a "128ke" actually has a few hundred bytes less free RAM, and it's enough to prevent it from running... one of these two, MacPaint or MacWrite. But I've never tried it so I can't say.
I'm *extremely* skeptical that Apple ever in any way signed of on this as an official upgrade and would be happy with an official service center doing it, but there was a thriving "gray market" for Mac upgrade parts despite Apple's attempts to rigidly control the supply, so I'm not at all surprised it existed in the wild despite that. Although, honestly, I don't see the point; if you're going through the trouble of having your Mac cracked for the ROM/disk upgrade you might as well have a third-party 512k RAM upgrade soldered in there while you're at it.
I thought that Apple probably charged a different price for upgrading a 128k vs. a 512k, but not sure enough to say. So, yes, the full from-zero upgrade of a 128k up to a Plus was just shy of $1,100, which while kind of painful was still well short of the price of a new Mac. (The Plus cost $2,600 at introduction.) A thing worth considering, though, is there's a less-than-zero chance that someone  upgrading their 128k to a Plus may have *already* ponied up for a 512k upgrade. Apple initially charged $999 for that, so worst case it's possible that someone could have ended up paying a total of $2,499 + $999 + $299 + $599 + $129 (keyboard upgrade) =  $4,525 for their Macintosh Plus if they stepped through every iteration.
It has round serial ports, so it's a Plus board. You can't swap boards without swapping case backs unless you're planning to do some plastic surgery.
Share this post
Link to post
Agreed. It's a rather silly penny-pinching move to only go half-way. Here's a Usenet post from 1988 mentioning a Mac 128Ke. Note that even the poster then had never heard of this configuration.
Quote
My source was this Usenet post from January 1986. I haven't verified the information in that post with any other source.
Edited by Dog Cow
Share this post
Link to post
Looking at that Usenet post I think the critical part is it's mentioned in the context of an accelerator/expansion board that included its own RAM onboard. (I'm going to hazard a guess the board they're describing is either the MacRescue or the same thing wearing another beard and mustache.) Boards like that would need the 128k ROMs to drive the SCSI controller they add (among other things) so it would be a prerequisite to have them, but you wouldn't actually be using the machine in a "128ke" configuration.
(It's notable that the ROMs in that picture of a MacRescue I pointed at appear to be EPROM pirates. No doubt that sort of thing was pretty rampant among... less than reputable... repair/upgrade shops.)
Share this post
Link to post
Right, but that's just one source mentioning a 128Ke. There are others that I've come across, but like I said, it's scarcely mentioned.
Share this post
Link to post
A quick update...
I struck GOLD with the 'Point of Sale' SE/30!!
Opened it up...and here's what I took out on my first night of 'restoration'.
Yep, a socketed Daystar 40MHz 68030 PowerCache accelerator card and what appears to be 32MB RAM on the logicboard, plus an Asante Ethernet card.
It was all pretty dusty, and I forgot to take a photo of the initial state (woops) though I was doing lots of iPhone video footage as well, I cleaned the logicboard and Daystar card with an anti-static brush to get rid of the worst of the dust. I haven't done any 'washing' of the boards yet and will need to be very careful as there is an OEM quality assurance or some sort of other sticker on the logicboard that I want to retain.
I really wasn't expecting this to have a Daystar card or more than 8MB RAM, the guy who sold it definitely had no idea he was selling me a goldmine for a very cheap price!
While I was at it, I also cleaned the floppy drive, it might need more work after a good 30 mins of cotton swabbing with isopropyl alcohol its looking a lot better, the auto inject & the eject seem to work smoothly now.
I have ordered a bunch of other stuff to help me with the Plus & upgraded 128K/Plus, I found a Plus mouse on eBay and an external 800KB floppy drive (both quite pricey but oh well...), just waiting for those to arrive in the post.
More to come soon!
Share this post
Link to post
 Wow, nice score. One of those socketed Daystar boards sold on eBay for $1200 recently. I suspect that will actually run at 50MHz by the way. Couldn’t read what’s on your clock can in the picture, though. Anyway that SE30 will feel blazing fast.
Share this post
Link to post
Congrats on the surprise socketed DayStar in that SE/30!  Like Crutch said, you're definitely coming out ahead on this conquest.  One of the more technically inclined folks will be able to confirm but I'd imagine if the 40MHz clock was swapped out for a 50MHz version you could either run CPU/FPU overclocked at 50MHz or you could swap in the respective 50MHz versions of each.  Even if you keep it at 40MHz that's still quite a fine surprise!
I do wonder what kind of life that machine lived before you got it though.  Dust that dark and pervasive makes me think some type of industrial shop.
Share this post
Link to post
Right. FWIW I haven’t seen one of these Daystar boards in person but I do have a couple Diimo030s, and those run at 50MHz by overclocking an 030 marked as 40MHz just like yours. (And they run flawlessly.)
Share this post
Link to post
Thanks for the extra info guys, I wasn't sure if it was sold in 33Mhz, 40Mhz and 50MHz versions, but if you say it just overclocks up to 50MHz then that also makes sense.
I have read before that these cards mean the processor gets really hot, and there isn't really room for a heatsink, but I'll have to see how it goes.
In terms of the history of the SE/30, on the front it has a sticker that says "POS" "Point of Sale Macintosh" so I think it was some sort of demo machine at one point.
The guy I bought it from was selling his dad's old stuff (or possibly his partner's dad's old stuff) who he said used to be a programmer for Commodore, so I guess he perhaps also did programming on Macs as well. Once I get it booting from the hard drive, I'm hoping the contents of the drive give a clue as to what it was used for.
For this machine to have been upgraded back then, when these upgrades would've cost in the thousands, it would've been someone where the cost was not an issue and they needed the power. Judging by the amount of dust, I think the unit was on perhaps 24/7 or at least for many hours each day, which ties in with it being a demo unit as well.
Share this post
Link to post
Or perhaps with it being POS, it was part of a till system...maybe it has some bespoke/custom/rare software on it !! Anyway I'll stop getting excited and will instead spend my time trying to get it working again...
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
