Jump to content
pep_one
Macintosh Classic II display horizontal thin lines
Recommended Posts
Hi, the story of my Macintosh started some years ago...
In short: I've recapped A/B and Logic board, after many repair session where I've bad voltage at 5V rails, now, after last isopropyl alcohol cleaning of A/B, the voltage is stable, the Mac boot and "Boing" playing (eureka! It's never boing).
But display always these thin horizontal lines. The lines is stable, after last cleaning, while before was flickering.
Do you have any idea of what is the culprit?
If I arrived at this point it is thanks to the posts of this forum. Thanks to all!
P.S: sorry for my poor english :(
Share this post
Link to post
Share on other sites
UE8
https://www.mouser.com/ProductDetail/595-SN74HC166AIDREP?R=SN74HC166AIDREPvirtualkey59500000virtualkey595-SN74HC166AIDREP
It’s all in the above post from UniServer.
BTW. How did you get the replacement 2N3904 so quick?
Just wondering, since you replied only 16 hours after my post.
I wish I was that quick!
Edited by jimjimx
Share this post
Link to post
I think that UE8 is the chip from Mac SE/30, I don't find it on logic board of my Classic II.
So I ask for the equivalent chip on my Mac.
Really I've replaced 2N3904 last night immediately after your answer, I taked it from an orphan A/B (I think is in good conditions), so I was very quick :)
Edited by pep_one
typo
Share this post
Link to post
Cheers,
Maybe i can piggyback on this thread as it seem a related problem:
Macintosh 12" Monochrome Display M1050
Picture faintly visible.
Some recaping but not much. Seems related to brightness / contrast setting but that could be just the visibility.
any hints before i unmount the rather unpleasant video board casing?
thanks!
Share this post
Link to post
I’m gonna recommend the link above I posted from UniServer.
See if that works out for you, gets you on a good path.
Theres a lot of learning in there.
Edited by jimjimx
Share this post
Link to post
Caps are starting to fail in the CRTs too, the 12" RGB version has a known issue with this in the horizontal drive stage.
For future reference, the issue you describe are whats known as "retrace lines" The fact that your screen looks like that (Referring to classic II), means your video signal is driven full on. So the CRT is literally biased well into the hot range, as retrace lines are usually blanked by the beam killer. (or blanking interval).
So, you either have a video amp IC thats on the classic II analog board thats bad, or the video IC on the logic board is bad. its one of the two. So unless you simply want to go on a parts swapping exercize, you need an oscilloscope to trace the video signal back through to figure out at which point its dying off.
The Monochrome LC monitor, it could be anything. My immediate thought is the contrast is way up. Again, biasing the CRT well beyond its range. Also, you could have a video amplifier issue.
This almost screams caps, or dirty/bad brightness/contrast pots.
Also, much more rarely, and only if someone has messed with it, the G2 (screen) drive on the flyback could be turned way too far and cause the issue as well on CRT monitors.
To sniff out bad capacitors, you could simply take the back off, grab a blowdryer, and start heating up the analog board in various areas. Even the CRT neck board if that fails, if the picture begins to improve drastically, then it needs a cap job.
Also look for wet/corroded/crusty areas near caps, this gives it away sometimes, but not always.
Edited by techknight
Share this post
Link to post
thanks for this very precise and educating answer.
the blowdryer method is new to me (love it) and i'll certainly try that.
there are no indications of leaking caps or other obvious things.
parts have arrived and i'll open the video board casing and see what's happening :)
as the retrace lines strongly react to the contrast / brightness dials i also would guess theres the root.
thanks!
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
