Jump to content
Storm
Mac IIci capacitor damage
Recommended Posts
Hi,
I'm new to this wonderful forum and I just got a really cheap IIci with a little bit of work to do.
It seems the SMD-capacitors leaked a little bit and left some components with nasty green legs :(
I already got replacement caps and removed the old ones very carefully. As I can see the pads are still in "working" order.
Any recommendations for cleaning the green stuff?
Share this post
Link to post
Share on other sites
Ok thanks I will try that.
What are my chances that the components still work when they got the green stuff on it?
Is there a schematic where I can find the types of the IC's so I can replace them if needed?
Share this post
Link to post
Generally as long as it's just green fuzz, you'll be able to clean it off and it'll just work(tm). There are some exceptions, like in a Mac IIcx the cap leakage likes to ruin the power-on circuitry and you'll never be able to turn the computer off again but that's a minor issue. More or less all the IC part numbers are directly on top of the chip. A few are Apple proprietary but those wouldn't be available 2nd hand anyway unless you pulled from another board.
Edited by Compgeke
Share this post
Link to post
Ok lets hope it works out :)
I cannot read anything on some IC's, they seem to have no part numbers on it. For example the UB2-Chip for left sound or the one for the right
Share this post
Link to post
Your board shows signs of battery damage at some point (rusty battery holder) and rust in the board itself.
Look under the battery holder, some traces can be damaged.
Edited by bibilit
Share this post
Link to post
I just replaced all the capacitors on the logic board and the power supply.
Now when I turn it on (via button on the rear), it powers up but shows only a grey screen with no chime. I also tried different memory sticks in both banks but that didn't help.
Any idea whats wrong with it now?
Share this post
Link to post
Did you clean the board, and I mean really clean the board after recapping? Cap goo gets under chips and causes weird issues until really cleaned.
Share this post
Link to post
Yes. Jinnai recommended using isopropyl alcohol but that didn't help that much with the green stuff on the IC-legs. Maybe there is some goo left under the chips.
I have a hot-air-station but I'm a little bit afraid to do that on the logic board. Is a pre-heater needed for desoldering the two sound-chips for example? I suspect there is some goo left under them
Share this post
Link to post
rotten traces probably.
The battery is close to the Rom chips, so i bet several traces are cut.
I will remove the battery holder and check continuity.
I had exactly the same problem with a IIci not so long ago, same behavior, gray screen, no sound.
I tracked the problem under the battery holder and made a repair on the other side of the board to keep things invisible.
for a test, i used a SE/30 Rom in the Rom connector and changed the jumper in the logic Board, got a chime but no picture, made the repair.. switched back to original setup and got a working IIci
Share this post
Link to post
Ok one of the traces you fixed was also cut and one another on the upper side. I fixed both but still the same issue. Grey screen and no chime.
Next I will try to clean the board
Share this post
Link to post
I found out that some of the 74HC132 and 74HC74 were damaged (Power Circuit) by the cap goo. I've desoldered them and ordered new ones. Maybe that's an issue too.
Some pins of these chips were broken
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
