Jump to content
AlpineRaven
Carrera040 in Macintosh IIsi
Recommended Posts
Evening all -
I recently acquired MicroMac's Carrera040 and I have not been able to start Macintosh IIsi.
Macintosh IIsi has been professionally recapped and is working 100%.
Once I install control panel & extension in the folders, Mode32 and or 32bit is active in System - doesn't matter which. RAM Doubler/vertical memory is off.
Hard drive is 160mb SCSI, 5mb RAM.
Installed it in System 7.0, 7.1 and 7.5.5 - it will not start up as it'll hang/freezes after the control panel loads up at start up (Welcome to Macintosh) with graphical artifacts. I've stripped the system folder to bare except those required extensions/control panels - still freezes.
Does anyone know workaround it?
Cheers
AP
Share this post
Link to post
Share on other sites
Hi AP.
Do you have another machine to test it on?
I have this exact card (sadly without the cache) in my IIci and it works fine, albeit it it leans to one side, so I jammed a cardboard wedge in there. But I digress.
Have you checked the 4 caps on the card? These often leak and suffer from poor solder joints too.
I replaced mine with Panasonic ones.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
