Jump to content
Sign in to follow this
JustG
Classic II is Alive!
Recommended Posts
I finally worked up the courage to clean, decap and solder in new tantalum capacitors (thank you trag) on my Classic II logic board.  It's not the prettiest but it worked!
The case is still pretty dirty and unfortunately it's a little dinged up but the next step is to clean it as best I can.  It has one of the round microphone holders glued to the side, I haven't quite decided if I should leave it alone or try to remove it.
The two bottom screws that hold the case together are missing so I'll need to figure out what size they are and get a couple more.
I works!  I'm so excited!
Share this post
Link to post
Share on other sites
Create an account
Register a new account
Sign in
Sign In Now
