Jump to content
Sign in to follow this
gryffinwings
Apple Color Plus 14" Display - Switch Problem
Recommended Posts
So my Apple Color Plus 14" Display works fairly well, however, the switch doesn't want to stay in the on position, I have to hold it for it to stay on. Does anyone know how to fix this?IMG_5895.thumb.jpg.beb37a9af987fca84350e1e15b3125fc.jpg
Share this post
Link to post
Share on other sites
23 minutes ago, bibilit said:
The only solution is to replace the switch.
Thank you for letting me know what the course of action is.
Now, are there any places I can get a replace switch need? and if not any appropriate substitute?
Share this post
Link to post
you have to look at the original switch and get a part number, its the only way to find out if there are any cross references or availability of existing components.
What fails is the plastic. there is a pin on the top of the switch that rides in the groove of the plunger itself, and it is a latch/unlatch mechanism. Sometimes the pin breaks and disappears, or the plastic cracks and breaks so the pin just falls straight through in the lastched position causing it to unlatch.
Share this post
Link to post
Fortunately I have a replacement on order, just going to take a while since the only places that have them are in China.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
