Jump to content
ryan9699
Writing 1.44MB floppies for SE/30 on OS Mojave 10.14.4
Recommended Posts
Hi everyone,
I recently got my hands on an old SE/30 and I'm trying to write some System 7.0.1 compatible programs on floppy disks. I'm fairly new to this stuff, so bear with me.
I have an external floppy drive, which I know works, because I can read floppies that are formatted by my SE/30. Only thing is, I can't write to them. I can only write to them if I first unmount the floppy (which nulls the formatting that is done on my SE/30). I'm getting successful results using the terminal command " sudo dd bs=84 skip=1 if=MacWrite.dmg of=/dev/disk2 ", but only after I've used " diskutil unmount /dev/disk2 ".
I know that the programs I'm writing are compatible, because I'm using the disk images on mini vMac, and they all run successfully. However, my main focus here is that I'm trying to avoid having to unmount the floppy, because using intuition, I think that it de-formats the disk, making the floppy unusable with the SE/30. I've loaded the floppies into the SE/30, only to be prompted with the typical "eject/initialize" message.
Can anyone offer some guidance as to what I should be doing, or where I should go from here? Thanks.
Ryan
Share this post
Link to post
Share on other sites
A modern Mac can’t write at all to an HFS formatted disk.  When you write with the dd  command you are not writing HFS you are just sector by sector writing an HFS image.  The dd  command doesn’t know anything about the format of the disk, it just sees bytes.  For that, overwriting the entire disk, it can’t be mounted because you are replacing the entire disk contents.
i know I saw someone mention on another thread leaving part of the above dd command out to get it to work.  I think it is the skip=1 part; I think that is only for creating an image from a floppy.  You might try that.
Edited by pcamen
Share this post
Link to post
You don't happen to have Windows on your Mac with bootcamp?  Or Windows running under something like Parallels on your Mac.  I say this cause I had your same problem but now use the program Macdrrive under Windows and its worked quite well for me.
Share this post
Link to post
Update: was able to get it to work by dismounting the floppy in DiskUtility (not in the terminal window using diskutil unmount, for some reason this never worked) and by typing in:
MacBook-Pro:~ name$ sudo dd if=filenamehere of=devicename bs=84 skip=1
to Terminal.
Not sure why it works for some people and not for others but... if anyone comes across this thread and needs help with this, it's a place to start. Thanks guys
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
