Jump to content
boh726
Mac Plus Ticking Noise...
Recommended Posts
I recently found a Mac Plus that someone was planning to throw away. After bringing it home, it turned on and worked perfectly, except for the lack of a startup disk. After getting the startup disks and trying to put them in, I realized the floppy drive wasn't taking them.
Fast-forward a month, I opened it up, took it apart to down to the drive, and cleaned and fixed the floppy drive. When I put the whole thing back together, it started making this clicking/ticking/chirping noise, with no startup sound and a black screen.
I've been through the whole thing, and can't imagine that it's one of the capacitors if it was just working. I looked at the Dead Mac Scrolls (of course) and both options for what is pressumable the flup-flup-flup noise dont seem be it. (The analog board is out of adjustment. The voltage is too high./The power/video cable is disconnected.)
I attached the sound, and also this piece of metal I found loose in the case. Maybe some connection. Hope someone has any idea what's going on.
clicking.m4a
Share this post
Link to post
Share on other sites
FYI, it may not be your exact issue but a ticking noise is normal with certain 800k drives until a disk is inserted and booted. And check your brightness dial.
EDIT: I coud not get your file to play, but now I did. I will leave the above for anyone else searching but its not the issue with yours. You have a problem with the sweep/analog board. It may be something as simple as a cold solder joint. Check all your connections and specifically where they are soldered in.
Edited by unity
Share this post
Link to post
Great, Ill look into it. Anywhere specifically, or should I just visually inspect the whole thing
Share this post
Link to post
7 hours ago, bibilit said:
Optoisolator is usually the problem here
Would that have changed with no prompting? Where would it be and how could I test it?
Share this post
Link to post
Quote
Yes can go wrong out of the blue, the opto-isolator is using an Infra red diode that can go wrong with time.
more about it here:
https://www.electronics-tutorials.ws/blog/optocoupler.html
No way to test it, but pretty cheap and socketed.
Located near the brightness knob on the bottom left of the AB.
Share this post
Link to post
I would first replace the 1000uf and 2200uf caps then check to see if your connector needs cleaning. If non of that works I would check the MB to see if your tsm chip has fried I have 2 boards with dead chips. I would also check to see if your flyback is good and if any other caps are cracked ot leaky. I have.had many macs that died during working on them. The mac plus I think is by far the worst and not fun either because they are so random even in perfect condition.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
